flashing lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by EDDERDS, Jan 17, 2022.
  1. Jan 17, 2022 at 1:23 PM
    EDDERDS
    EDDERDS [OP] Member
    2015 Tacoma 2.7 2wd ext cab
    none
    Disconnected battery for safety while removing an aftermarket amp that had main ground cut . Reconnected battery, now when the doors are open all dash lights, and parking lights flash, they do stop awhile after the door is closed. Start it up and the lights start flashing again, they will stop in a bit. Drive it and the lights flash intermittent but not as often. Everything seems to work as it should, lights, turn signals, emergency flashers, radio, engine, trans etc. Must be a short but where do I start looking??? 2015 Tacoma SR5 2.7 auto 2wd.
  2. Jan 17, 2022 at 1:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    All the dash lights flash?
    Or just the turn signal lights?
    This is an odd one, can’t say I’ve heard of anything like this.
    Do you have an aftermarket alarm?
  3. Jan 17, 2022 at 1:41 PM
    EDDERDS
    EDDERDS [OP] Member
    none
    all interior lights and parking lights, radio lights etc. flash. stock alarm disconnected. Everything was wonderful until I disconnected the battery???
  4. Jan 17, 2022 at 1:46 PM
    TnShooter
    Deogee
    STOCK
    A lot of the 2.7 trucks didn’t come with an alarm.
    What does your key fob look like?
    This really sounds like an alarm system issue to me.
    I remember someone having a similar issue with their horn.
    It would blow anytime they inserted the key. This happened after they replaced the battery?
    Turned out to be the alarm system (aftermarket)
    Jimmyh and Dm93 like this.
  5. Jan 17, 2022 at 1:54 PM
    EDDERDS
    EDDERDS [OP] Member
    none
    hummm, just bought the truck, looks like an alarm horn mounted to interior of left front fender, but is not connected to anything don't have a key fob just a regular key.
  6. Jan 17, 2022 at 2:21 PM
    TnShooter
    Deogee
    STOCK
    You might have to look around inside the truck.
    Sometimes there is a rest/bypass button.
    Maybe look under/around the bottom dash.
  7. Jan 17, 2022 at 2:59 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You can try putting the key in the door and unlocking it, sometimes that will satisfy the alarm system, definitely sounds aftermarket.
    Usually if you look at the wiring underneath the steering column you can find them pretty easily.
    TnShooter likes this.
  8. Jan 17, 2022 at 7:09 PM
    EDDERDS
    EDDERDS [OP] Member
    none
    don't see a reset or bypass button, what would it reset?
  9. Jan 17, 2022 at 7:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did you try unlocking the door with the key like I said?
    If it's indeed aftermarket you need to find the unit and identify it to get instructions on disarming it.
  10. Jan 17, 2022 at 9:17 PM
    Waasheem
    Waasheem
    2007 xrunner
    I have an aftermarket alarm. If I do something odd like lock the door with the key or door switch, then open with the alarm remote, it does weird things. Then if I undo whatever I did, open the door locks with the key, everything goes back to normal.
  11. Jan 18, 2022 at 1:39 PM
    EDDERDS
    EDDERDS [OP] Member
    none
    yes, locking & unlocking with the key doesn't help, every time a door is open things start flashing.
  12. Jan 18, 2022 at 7:17 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ll bet you have an aftermarket alarm, noise maker alarm flashing lights without ignition kill. Someone cut the wire to the noise maker, and had it set in valet mode. Disconnecting the battery somehow disengaged valet mode.
    You’ll need to dig and find the alarm, find the brand name on it, find an alarm dealer that works on and sells that brand. If it’s a good one, it might be worth buying a remote for it, if the company didn’t go out of business.
    Or really any car alarm place could probably remove it for you. Going in and cutting wires yourself could cause problems. So if you think about doing it, if it isn’t very obvious how to do it, you shouldn’t. A good installer would make it difficult to easily remove.
    Dm93 likes this.
  13. Jan 19, 2022 at 9:14 AM
    EDDERDS
    EDDERDS [OP] Member
    none
    Thank you I appreciate your advice.
    Waasheem likes this.
  14. Sep 13, 2022 at 3:00 PM
    Chrisffff
    Chrisffff New Member
    Tacoma
    None
    Did you ever find the cause of this
  15. Sep 13, 2022 at 3:15 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Welcome!
    Don't you just love it when these guys leave ya hanging. They tell you the problem, symptoms and then total radio silence.
    If you put @ in front of their name (ex) @Chrisffff it will alert them about your message. Or you can quote their post.
