Flat or Dinghy Tow a Tacoma - why not?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgord, Apr 25, 2019.
  1. May 13, 2021 at 1:12 PM
    #101
    TAP64
    TAP64 Member
    Todd
    2021 TRD 4x4
    Blue ox tow bar, base plate. Superior driveline disconnect
    What about towing in park?
  2. May 13, 2021 at 6:53 PM
    #102
    bsharpe
    bsharpe Well-Known Member
    Brian
    Central Illinois
    2019 DCSB 4x4 Off Road
    Driveshaft disconnect to be flat towed behind our RV.
    After reading this thread again and flat towing my Tacoma in both park and neutral for 5000 miles.
    I have decided to join the park side!:cheers:
    CXYyuppie and TAP64 like this.
  3. Jun 1, 2021 at 1:33 PM
    #103
    ORtoCOTaco
    ORtoCOTaco Well-Known Member
    Colorado
    2018 White Tacoma TRD Off Road DCSB 4x4
    BodyArmor 4x4 HiLine Winch Bumper, Warn Zeon 10-S, Uptop Bravo Roof Rack, ExtremeLED Super Stealth 40" LED Light Bar, DV8 Offroad 20-Inch BRS Pro Series LED Light Bar, Truxedo Roll-Up Tonneau Cover, Automatic Tailgate Lock, Trailgate panel, cheap Amazon ditch lights.
    You all mind if I ask what it costs to buy the disconnect itself and/or with installation? It looks easy enough that I could install but if having a qualified mechanic doing it is only a couple hundred that may be a good route.
    My wife has, surprisingly, started talking about wanting to sell our house and travel the country in an RV in a couple of years. Bought my Taco with the intention of driving it to 300k so I wouldn't be ready to give it up in 2 or 3 years!
  4. Jun 1, 2021 at 1:42 PM
    #104
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I bought my disconnect new for my 4runner and had my local driveline shop install it. It involves cutting and welding the shaft. They could not get it to balance after and said they would never do one again. That said, installing the modified driveshaft is super easy. There is a mechanical portion that attaches to the 3rd member that has a cable that runs into the cab for you to pull to disconnect the shaft. That was relatively easy to install but not off road worthy imo. On my 4runner I have 2 DL's since the disconnect DL has a vibration. I don't tow the 4runner often so I swap them out when not in use. I don't use the cable and mechanism anymore. I crawl under there and manually slide the coupling to connect/disconnect.
    On a Tacoma, which I also have, the best thing to do, I think, is to install a manual transfer case. Now you have neutral to shift into which disconnects. Plus you get the manual TC.
  5. Jun 1, 2021 at 8:25 PM
    #105
    TAP64
    TAP64 Member
    Todd
    2021 TRD 4x4
    Mine was around 1100.00 I installed it myself. Using a battery disconnect to get around steering lock. No problems so far.
    ORtoCOTaco[QUOTED] likes this.
  6. Jul 31, 2023 at 1:19 PM
    #106
    Mike1950
    Mike1950 New Member
    2022 Toyota Tacoma 4x4 Double Cab
    Stock
  7. Jul 31, 2023 at 2:37 PM
    #107
    Derk33
    Derk33 Well-Known Member
    Derek
    Pennylvania
    22 Army green TRD OR
    In a manual transmission it relies on splash lubricantion from the gears turning. The gear closest to the input shaft is permanent coupled to the input shaft (its always turning as long as you don’t push the clutch) this gear is meshed with the countershaft. This means the countershaft is always turning thus turning all the gears on the output shaft. The gears on the countershaft are normally locked on with a press fit while the gears on the output shaft are free to spin until a gear is selected. This is basically how the splash lubrication system works.
    Now that we understand how the lubricantion system works we can see that with the engine off and being flat towed only the output shaft would turn. If the gears don’t turn the surfaces between the output shaft and the gears will receive no oil and will burn up, ruining the transmission.
    For legality reason I still don’t condone flat towing it but if you were to remove the rear driveshaft you could flat tow a Tacoma. I know when semi trucks are towed the tow truck drivers either drop the driveshaft or pull the axle shafts for this very reason.
  8. Jul 31, 2023 at 3:50 PM
    #108
    dwphoto
    dwphoto Well-Known Member
    Elliott
    Thousand Oaks, CA
    Big Toyota Guy
    Big Flat tow guy here
    My Check list
    hook up tow bar
    Safety cables
    Hook up Trailer lights
    Ebrake off
    Hubs unlocked
    The key on
    the battery disconnected,
    Neutral for short trips.
    Pull the driveshaft and tie it up to the frame, it's 4 bolts. Takes an extra 5 mins
    Install Bob.
    Seatbelt Bob
    GilbertOz likes this.
  9. Jul 31, 2023 at 3:52 PM
    #109
    Y2kbaja
    Sacramento
    Total Chaos
    I need a Bob.
    dwphoto likes this.
  10. Jul 31, 2023 at 8:56 PM
    #110
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Almost none of that is true for the Tacoma.
    1. The Tacoma input shaft is not directly geared to the counter shaft.
    2. The Tacoma output shaft is geared directly to the counter shaft.
    3. Reverse, 1st, and 2nd gear are fixed on the input shaft and free on the countershaft. 3rd, 5th, and 6th are fixed on the countershaft and free on the input shaft.
    Even Toyotas that do use an input shaft fixed to the countershaft are frequently approved for flat towing.
    A manual transmission Tacoma will have everything in the drivetrain lubricated normally if set correctly. If there’s a reason not to flat tow it, it’s not that.
    Jeff
    GilbertOz and BLtheP like this.
  11. Aug 2, 2023 at 9:45 AM
    #111
    23 SR5 LB
    23 SR5 LB Well-Known Member
    2023 White Tacoma SR5 LB
    FYI. I have researched what it would take to make my 23 2WD ready for flat towing. After ~15 years of towing a FWD car with a dolly behind our motorhome, I prefer to not do that anymore. Insurance company also stated no concerns with insuring both the motorhome and toad with this configuration (despite what the manual states).
    1. Supplemental braking system. There are many brands (Demco, Roadmaster, Blue Ox).
    2. Tow bar - Roadmaster, Blue Ox, Curt, Demco or Blue Ox. Just make sure it will attach to the brand of baseplate you choose below.
    3. Baseplate kit Roadmaster or Blue Ox
    4. Superior driveline disconnect https://remcodsc.com/ $2000 - $2600 installed. Or you can install yourself.
    5. Some type of auxiliary brake light setup (hardwired or magnetic)
    There are a lot of options so total price varies.
    Have a great day.
  12. Aug 29, 2023 at 11:29 AM
    #112
    sabu
    sabu Squirrel Driver
    Ron
    So. Cal.
    MG 4x4 TRD OR AC
    XM Radio, Redline hood lifts, X-tra bed tie-downs
    Same as 23 SR5 LB, except I slide under and undo the four flange bolts and tie up the rear shaft. I’m concerned that the Superior disconnect might be a failure potential when wheeling hard.
    It’s really easy to disconnect the 2009 TRD Off Road flange once you practice. I keep a “disconnect kit” in the truck all the time. Ground cloth, 1/2” battery impact, scissor jack to lift a tire so I can spin the shaft for access to bolts. Takes 10 min.
    Vulcan rechargeable remote lights eliminate the need to screw with OEM wiring. And the RVi brake is a snap to set in place (I also pull a CJ).
