Flat towing a 3rd Gen 4x4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jallen355, Oct 26, 2019.
  1. May 9, 2024 at 2:33 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Toyota says no.
    Many people have flat towed the 3rd Gen with manual trans. Ensure it’s in 2nd, trans in N, tow on
  2. Jul 23, 2024 at 12:40 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Apparently the 3rd gen needs a driveshaft disconnect to flat tow without risking damage to the transfer case (regardless of auto or manual transmission.)
  3. May 5, 2025 at 5:40 PM
    danojeno
    danojeno Well-Known Member
    Inland Empire, CA
    2017 Tacoma CCSBORMT Silver
    Elka 2.5DC Camburg UCA Deaver AAL 275/70/17 KO2s
    Firing this up to see what's been done. Has anyone converted rear axle to full floating and installed locking hubs?
  4. May 5, 2025 at 5:51 PM
    Gen3TacomaOBX
    S
    The Superior driveline disconnect is working well for me so far with ~8k miles towing the Tacoma 4 down.
  5. May 28, 2025 at 1:48 PM
    chrisrhere
    chrisrhere Well-Known Member
    2019 Tacoma trd pro
    what are the things you’ve done for flat towing? Is yours push button?
  6. May 28, 2025 at 2:21 PM
    Gen3TacomaOBX
    S
    Negative. I am old school H-Key instead of push-to-start.
    I've done the following:
    • Added a steel winch cradle that has integrated towbar attach points.
    • Added Roadmaster RM-152-LED-7 wiring and brake bulbs.
    • Added Roadmaster 156-25 Towed Vehicle Charge Line Kit.
    • Wired the truck for a Brake Buddy Select.
    • Installed a Superior/Remco driveshaft w/driveline disconnect.
    • Purchased a towbar that supports more than the weight of the truck.
    The Charge Line Kit keeps the trucks battery charged when towing. We're up to 9k miles towing the Tacoma.
    This thread (Towing 4 down with AT) has some info on how to get past the Push-to-Start issue for flat towing.
