Flat towing a 4wd tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jerry1047, Jun 27, 2017.
  1. Jun 27, 2017 at 4:01 PM
    Jerry1047
    Jerry1047 [OP] New Member
    Jerry
    am not presently a tacoma owner(have owned 4 previously) and am considering buying another to tow behind our motorhome. Question is - can a 4wd be flat towed without any modifications? Also, does anyone out there have any experience with a drive-shaft disconnect device that is presently on the market?? Any comments would helpful (well almost any)
  2. Jun 27, 2017 at 4:04 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Cannot flat tow (dinghy) without disconnect or getting dirty under the truck for 10 min.
    Unless its a manual.
  3. Jun 27, 2017 at 4:20 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Get a trailer, flat towing is dumb.
  4. Jun 27, 2017 at 4:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't know of any disconnects, but it's only a few bolts holding it to the rear axle. It'd be easy to just undo the rear and tie it up out of the way.
  5. Jun 27, 2017 at 4:30 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You can flat tow a manual trans but not an automatic. Just remove the rear drive shaft if it's an automatic at the support bearing you can still drive it around in 4WD if you need to move it. If the front wheels are on the ground be sure to take it out of 4WD before you tow it. I have never tried it but I'm thinking once it's turned off it reverts to 2WD any way.
