Flatbed Information Thread
Discussion in 'Technical Chat' started by tacoma16, Jul 11, 2018.
  1. Feb 9, 2023 at 11:04 PM
    #341
    taco.habit
    taco.habit Member
    Austin
    Los Osos
    08 AC 4.0 6MT 4x4
    First off thanks everyone for the help with my not-so-flatbed bed replacement project. I built a micro camper for my 08 and used a ton of info from this thread so I thought I'd share what worked and didn't.
    Here's what I built:
    For my lights, I've run almost everything through the factory 7 pin trailer connector so the brake lights and turn signals would be integrated and I wouldn't have to add a separate housing. The only exception is that I recently ran a third brake light straight from the brake light housing so it wouldn't blink with the turn signal but that wont apply to most flatbed folks.
    I've since moved the fuel filler location higher and toward the cab. Having it lower than the stock location worked for the better part of a year then became temperamental and started spilling. I ended up cutting the filler neck off with the factory lines in place then adding the 3 corresponding hoses between the cut pieces to extend the filler to the new location.
    [​IMG] [​IMG]
    fatfurious2, 9mmMike, d.shaw and 11 others like this.
  2. Mar 6, 2023 at 12:03 PM
    #342
    Halliwax
    Halliwax Well-Known Member
    Capital District
    Might put my Ute on the market this spring if anyone is interested!
  3. Mar 7, 2023 at 8:16 AM
    #343
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    Interested but probably not in the budget, would like to see it if you're ever down in the Columbia County neck of the woods!
  4. Mar 12, 2023 at 1:46 PM
    #344
    Halliwax
    Capital District
    Ralf and ExplorHer like this.
  5. Mar 15, 2023 at 8:19 PM
    #345
    mcfarty
    mcfarty Well-Known Member
    mcfarty
    Jackson, WY
    2019 White Tacoma OR LB
    6112 Front and 5160 Rear with AAL ECGS Bushing replacement Prinsu Roof Rack FourWheelCamper Swift and Tradesman Camper Shell Custom bed modular platforms and storage units KO2's and Blizzaks Pioneer 6600 upgraded head unit Engine Core heater OEM
    Do you happen to know how much higher the flatbed is above the stock beds height?
  6. Mar 15, 2023 at 8:22 PM
    #346
    mcfarty
    mcfarty
    Jackson, WY
    Any chance you know how much higher the mits flatbed is compared to the stock bed?
  7. Mar 28, 2023 at 9:49 AM
    #347
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
    How are these ting brackets able to support everything. I’m sure they do since I see them ALOT but it’s really surprising. Any engineering with insight
  8. Apr 15, 2023 at 12:43 PM
    #348
    Ralf
    Ralf Summit Expedition Trucks Ltd.
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    ARB Summit Bar Safari Snorkel
    shiftd, tacoma16[OP] and Shveet like this.
  9. May 12, 2023 at 11:28 AM
    #349
    ThinBimini
    ThinBimini Member
    Thin
    2001 TRD
    I used a Double Diamond Fab kit that I modified to keep the clearance of my previous setup. As of now, it is far lighter than when I had the bed+bumper+canopy+swingout.
    TRD_IV, shiftd, TimberTiger and 8 others like this.
  10. May 12, 2023 at 12:56 PM
    #350
    Clamber247
    Clamber247 2004 Tacoma
    Boise, ID
    Looking great and I have been eyeing up their kit as a replacement to my swiss cheese of a bed.
    What did you end up modifying and ~ how much do you think the flatbed weighs?
    Also, what brand are those boxes? Going to build a similar setup and have my ripcord esq topper sit on top of them.
    ThinBimini[QUOTED] likes this.
  11. May 12, 2023 at 1:48 PM
    #351
    ThinBimini
    ThinBimini Member
    Thin
    2001 TRD
    1) I trimmed the tail section waaaayyy down so it doesn't get hung up on stuff. Maybe 8" inches or so.
    2) Maybe 80lbs more than the stock shortbed. Me and another guy lifted it into place without a problem. Now I don't need a separate beefy bumper so that saves a lot of weight.
    3) Those are Buyers Pro aluminum boxes. They are pretty tough to break into. I had a ripcord style canopy but Seattle's homeless took it as a challenge. Someone would trash it every couple of months trying to break in. Unless I was on a trip, I only kept an emergency kit and a spare tire so there was nothing to steal. Still super annoying, though. Since the canopy was shiny I could see anytime someone would check the locks (in the dust or finger smudges) just to see if it was open- which was at least once a week.
    Naveronski likes this.
  12. May 12, 2023 at 1:53 PM
    #352
    Kombi
    Kombi Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    Just starting my flatbed build. For those that build in aluminum. How thick of wall did you run? I'm thinking. 25 for my mounting and .125 for basically the bed. Built off 2x2 tube.
    Just pulled my bed and started my hitch/recovery points.
    This is what I am looking to built
    And where I am now lol
    I am hoping this will weigh less and be removable on certain camping trips (dunes ect ) .
  13. May 12, 2023 at 1:56 PM
    #353
    Kombi
    Zack
    I debated doing this as they are local.. looked like a nice kit, just wouldn't work for what I was after
    Ralf likes this.
  14. May 13, 2023 at 3:08 AM
    #354
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    Very nice set up @Kombi !
    I am almost done with my flatbed design but I’m stuck in Europe for work for another 3 months with out my truck :annoyed:
    what size square tube is everyone using for the structural frame members?
    Naveronski and jpereira2 like this.
  15. May 13, 2023 at 9:16 AM
    #355
    Kombi
    Zack
    Where did you get that shortbed frame? I have been looking and only have a long bed one to play with.
  16. May 13, 2023 at 11:04 AM
    #356
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    It’s a 2015 access cab frame (90% sure) but i 3d scanned my DCSB bed and the bed mount bolts line up almost perfect to 4 of the 6 bed mounting locations on the frame model.
    My best guess is that the frame is the same on the access cab and DCSB but there is an addition bracket for the front 2 bed mounts.
  17. May 13, 2023 at 11:21 AM
    #357
    N minus 1
    San Diego, CA
    2014 TRD Off Road
    The rear 4 bed bolts have an axis through them. The extra bracket for the front two bed bolts on the access cab are circled in red (section analysis view)
  18. May 16, 2023 at 7:54 AM
    #358
    Kombi
    Zack
    Here is where I have made it so far.. should have the bed attached to the frame tonight. I'll start on the headache rack, water tank brackets, battery brackets, drawer, and side boxes.. so a ton left lol20230515_192115.jpg
    rob1208, ExplorHer, bhigbee and 2 others like this.
  19. May 21, 2023 at 9:43 AM
    #359
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    bumper/winch cradle is done, finally starting on the floor planks!
    347281632_150894764644752_24187020988986_4896b96fb141df76182592b3d66c40f552e3037f.jpg
    9mmMike, ExplorHer, Ralf and 5 others like this.
  20. May 21, 2023 at 10:01 AM
    #360
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Lots of cool builds happening!
