Flatbed Information Thread
Discussion in 'Technical Chat' started by tacoma16, Jul 11, 2018.
  1. Jun 15, 2024 at 8:53 PM
    #461
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    We're actually going to be building another bed soon and our plan is a steel frame with aluminum boxes and an aluminum deck to save weight. Send me another message and we can discuss some more options.
    Naveronski[QUOTED] likes this.
  2. Jun 15, 2024 at 9:00 PM
    #462
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Done
  3. Jul 13, 2024 at 11:07 AM
    #463
    700cinema
    700cinema Well-Known Member
    2014 Tacoma V6 4.0L 4x4 AC FLATBED UTE
    Update: drop down sides finally have the hinges I wanted from Australia zink coated and welded well it the steel. Plastic bushings make a snug fit. Just neeed to PC or paint and latches. Needed to add weight for my expo springs each side is 40lbs also didn’t need any hardware found my old t30 torx bolts from my old bed
  4. Jul 13, 2024 at 1:10 PM
    #464
    firemaniac
    firemaniac Well-Known Member
    Northwest corner of Montana, Troy/Yaak area
    04 DC 4x4, Flatbed, auto, teardrop tugboat.
    Flatbed, Bilstein/OME 883 lifted, ARB bumper, Warn M8000, Onboard air, Onboard water system, Lights, Lights, Lights
    I did similar with the hinges on my sideboards, with the biggest difference of having the pins facing the other direction. My thoughts in this were keeping the sides kind of trapped when they are in the up position between the hinge pin, and the headache rack so they don't slide off the back, and be able to take the tailgate off and still drive when needed.
  5. Jul 13, 2024 at 2:04 PM
    #465
    700cinema
    That was the initial idea, but Clarence with the body unfortunately very slim areas to move them back and off so I had to do what I had to do … Connecting clamps to the headache rack, are lockable. In theory, I could just swap as side and flip the pin the other direction …. But one side is cut out specific for a tiedown point
    firemaniac[QUOTED] likes this.
  6. Jul 13, 2024 at 2:18 PM
    #466
    700cinema
    tacoma16[OP] likes this.
  7. Jul 23, 2024 at 11:45 AM
    #467
    dome
    dome Well-Known Member
    Joel
    California
    2015 TRD OR DCSB 4x4
  8. Sep 13, 2024 at 9:50 AM
    #468
    Naveronski
    Fort Worth
    Has anyone seen any updates for these?
    We had a couple "new" players but none seem to have made it to market yet.
  9. Sep 13, 2024 at 2:14 PM
    #469
    Naveronski
    Fort Worth
    Did this build happen?
    AllTacosFloat likes this.
  10. Sep 13, 2024 at 3:02 PM
    #470
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    It didn't actually. The guy found a great deal on an OEV bed so he went that way.
  11. Nov 10, 2024 at 8:44 AM
    #471
    FarmerBrerin
    FarmerBrerin New Member
    Hi all, I’m welding up an aluminum flatbed for my 2023 SR DCSB; I got 1/4” aluminum diamond tread plate and 1.5x2.5x0.125” rect tube for the structure underneath and need to do the beam or attachment for the frame. I’ll be using the extra tread plate for the skirt and mimicking a CM bed style. My question comes in with the fuel fill; I was hoping to put it up and in between the headache rack and the cab with one of the U-bolt designs. I hear mentions of the 4Runner fuel filler; does that help with getting it over there or how do I bend/fit the tube over there? I presume it’s rigid?
  12. Nov 10, 2024 at 3:44 PM
    #472
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    0xDEADBEEF likes this.
  13. Nov 13, 2024 at 11:08 AM
    #473
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    @Chux
  14. Nov 13, 2024 at 11:13 AM
    #474
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    The biggest problem i ran into is that the filler ended up being much lower and closer to the tank. Ended up cutting down the factory fuel filler and welding a hose barb onto it, then used a fuel filler hose to connect. Worked pretty good, just a tight squeeze.
    Used this, or something close:
    https://www.millsupply.com/unleaded-fuel-filler-neck-black-cap-reduces-81937.php?p=324374
    soundman98[QUOTED] likes this.
  15. Nov 14, 2024 at 1:24 PM
    #475
    Chux
    Chux Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    :wave:
    essjay, la0d0g, 0xDEADBEEF and 6 others like this.
  16. Nov 15, 2024 at 5:23 AM
    #476
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Just some photos of how versatile the flatbed is. Mines still going strong and really like having a cap with a floor that slides on and off really easily.
    going from hard trail day, no bed sides to get stuck up against trees
    To loading scrap metal (this was the body off of a 4Runner from a buddies parts car)
    Toyotico, essjay, rob1208 and 10 others like this.
  17. Nov 21, 2024 at 2:52 PM
    #477
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    Where did you order your MITs from? I priced one locally and it was pretty pricey. The dealer is also famous for massive markups on stuff though.
  18. Nov 28, 2024 at 10:32 AM
    #478
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Purchased through Mule Expedition Outfitters Hq in Issaquah, Washington. Installed in Tualatin, Or., (no sales tax).
  19. Dec 8, 2024 at 8:17 AM
    #479
    RS874903
    RS874903 Well-Known Member
    Ohio
    4x4 Tacoma 4L V6 Pyrite Mica
    Step 1 done.
  20. Dec 11, 2024 at 10:20 AM
    #480
    SGalvanNerd
    SGalvanNerd Well-Known Member
    This is so badass
