Flatbed Information Thread
Discussion in 'Technical Chat' started by tacoma16, Jul 11, 2018.
  1. Mar 7, 2021 at 2:17 PM
    #161
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    appears to be a uteltd bed. However it seems shorter since there is only 2 hinges on the sides of the bed? Correct me if I am wrong @Halliwax
  2. Mar 7, 2021 at 5:37 PM
    #162
    Halliwax
    Halliwax Well-Known Member
    Capital District
    Correct, it's a Ute Ltd. It's a K55 bed (69"Wx5.5'L) as opposed to the C6 (73"x6') that I've seen others run.
    tacoma16[QUOTED][OP] likes this.
  3. Mar 7, 2021 at 5:39 PM
    #163
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Ah gotcha. Remember you mentioning k55 but didn’t consider there was a difference. Good to know
  4. Mar 7, 2021 at 5:41 PM
    #164
    Halliwax
    Capital District
    Bought it from Ute Ltd in Australia. Randy is the point person in the states and he's awesome. The bed is around $2400~, shipping to the east coast was a little over $400, probably sunk a few hundred more into the bumper (which is a complete knockoff of 1 Bored Clerk on here. He was nice enough to even dig up the bumper bracket template file for me).
    tacoma16[OP] and Windigo like this.
  5. Mar 7, 2021 at 5:43 PM
    #165
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    I like thoes numbers:)
    Halliwax and tacoma16[OP] like this.
  6. Mar 7, 2021 at 5:55 PM
    #166
    Halliwax
    Capital District
    You and I both. Was a simple choice once I started to crunch the totals. Norweld is great, but even at the same price point I think I'd choose the Ute Ltd. It's a much simpler design and that's more my taste.
    Windigo[QUOTED] and tacoma16[OP] like this.
  7. Mar 7, 2021 at 6:04 PM
    #167
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I wish I would have gotten the smaller version. Don’t recall knowing about it at the time. Would have been nicer on the trail. Mind you the beds hold up pretty good to trees so far.
    Windigo likes this.
  8. Mar 8, 2021 at 6:16 AM
    #168
    Halliwax
    Capital District
    I had no idea the K55 existed either. I had originally contacted Randy about a C6 and he had brought it up as an option.
    One of the things I had been doing a deep dive on before buying was trying to find pictures showing how wide the C6 stuck out on the sides. From the few pictures I could find it was a little more than ideal, but I was going to go for it regardless. Once I heard about the smaller size I was all in.
  9. Mar 8, 2021 at 6:25 AM
    #169
    Halliwax
    Capital District
    There were definitely some hurtles with the K55, however. I had mentioned that the (265/70) tires stuck out a bit, which isn't a deal breaker since I'm moving to 235/85s. That poke means that the supplied mud flaps don't line up either, so I'll be making some brackets to squeeze those in somehow. Biggest hiccup was that the bed brackets line up in such a way that you can't use the factory mounting point to attach to the frame. Had to weld a small extension on to get anything to work. Again, not a big problem, just something that the next guy should be looking forward to.
    giddie and tacoma16[OP] like this.
  10. Mar 8, 2021 at 8:13 AM
    #170
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Interesting. I had to modify my frame mounts as well but it’s good to know about the tires. My 315’s poke out as is with the bigger bed so it worked out I guess.
  11. Mar 8, 2021 at 10:10 PM
    #171
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  12. Mar 9, 2021 at 11:22 AM
    #172
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Sherptek has some interesting solutions to storage problems.
    My main concern is that it’s illegal to modify you fuel system according to federal smog guidelines. That means relocating your fuel filler is a no no here on the west coast.
    Ralf and RyanDCLB[QUOTED] like this.
  13. Mar 9, 2021 at 6:27 PM
    #173
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    I guess mine is a “bit different” in design and function than a traditional Ute style flatbed. I have more of the “Overland” style in mine.
    RyanDCLB likes this.
  14. Mar 10, 2021 at 9:42 AM
    #174
    Ralf
    Ralf Summit Expedition Trucks Ltd.
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    ARB Summit Bar Safari Snorkel
    That's an interesting note then. Is that just a California only issue?
  15. Mar 10, 2021 at 9:52 AM
    #175
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Ontario Canada you technically need a commercial inspection when going to a flat bed.
    Anderson likes this.
  16. Mar 10, 2021 at 10:00 AM
    #176
    Ralf
    Ralf
    Fort McMurray, AB
    '17 TRD Off-Road
    Which is sucky. Thankfully for the Tacoma's, they can fly under the radar. As far as I know, you haven't any issues with MTO, correct?
    My comment was at the fact of the fuel filler relocation. Wondering if that's a California issue only about the smog.. Since with our production model we were looking at modifying the fuel filler neck for better filling capabilities at the pump.
  17. Mar 10, 2021 at 10:04 AM
    #177
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Ah gotcha. Yeah so far so good with mto.
    as for fuel, who knows. The laws pretty much don’t let you touch anything and safeties are so subjective. I failed a safety because I had aftermarket bumpers at one shop. Dealer had no issue with it. So annoying.
    Ralf[QUOTED] likes this.
  18. Mar 10, 2021 at 9:28 PM
    #178
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Federal, unless you register your truck as flatbed commercial. You are still required to stop at all scales with a flatbed. But, I’ve never seen a CHP go after a midsize truck with a tray.
    tacoma16[OP] and Ralf[QUOTED] like this.
  19. Mar 11, 2021 at 4:46 AM
    #179
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    That's weird; Texas has no such laws for flatbed pickups.
  20. Mar 11, 2021 at 8:51 AM
    #180
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    It’s actually Federal guidelines. It’s mostly overlooked by states that have minimal smog requirements. But, here in California, it’s something they pay attention to.
