Flaten Exhaust... Maybe...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sprocket1505, Jun 30, 2016.
  1. Jun 30, 2016 at 5:13 PM
    Sprocket1505
    Sprocket1505 [OP] Well-Known Member
    Think I might have flatten my exhaust going over a hill. Def hit it b/c there is mud and small groves on the metal, but the top looks crimped. It protrudes down farther than anything else under there. Have you guys seen this or is that pipe crimped from the factory for this reason?
  2. Jun 30, 2016 at 5:18 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    From factory:)
  3. Jun 30, 2016 at 5:23 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You'll see more dimpling and scratches on your exhaust if you flatten it, short of lowering your truck on a perfectly flat piece of something, it will not be uniform like that, its normal.
  4. Jun 30, 2016 at 5:27 PM
    Ecrub
    Ecrub Well-Known Member
    Eric
    Brea, Ca
    2016 DCSB TRD OR 4x4
    Ha I thought the same thing after hitting something under my truck after an off road trip. Good to know it was already there before me :amen:
  5. Jun 30, 2016 at 5:29 PM
    Sprocket1505
    Thanks guys, I was already looking to replace it. Looked like it would been any easy fix. Need some guards down there.
  6. Jun 30, 2016 at 6:42 PM
    Broccoli
    Airdrie Alberta
    Theres a mod in the 2nd gen forum to run it another route so its not the lowest under the truck.
