Flattened leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boudain, Mar 25, 2018.
  1. Mar 25, 2018 at 11:02 AM
    boudain
    boudain [OP] Well-Known Member
    Bobby
    South Texas
    2015 DCSB TRD Off Road 4x4
    TRD Sport Scooped hood...for science!
    Was taking the steps off the truck and noticed that my leafs look flat. Now in the pic the front end is elevated a few inches due to my driveway slope, so I understand that the rear suspension was loaded down a bit. Even with that in mind, I don't think I've seen leafs this loaded, even on my last Tacoma.
    Time for an upgrade? If so, what's a good option to keep/improve payload capability?
  2. Mar 25, 2018 at 11:04 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  3. Mar 25, 2018 at 11:10 AM
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    I'm pretty sure you can get a set from the dealer for free...
    Isn't there a recall or something/?
  4. Mar 25, 2018 at 11:17 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    He has four leafs. Im not sure its for his situation?? Someone else who knows better can help...
    BadgersFan likes this.
  5. Mar 25, 2018 at 11:55 AM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    shit, gonna have to look at mine now
  6. Mar 25, 2018 at 11:57 AM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Time to upgrade the leaf packs to dakars!
    He already has the TSB pack because he has 4 leafs and 6 clips per pack. The non tsb pack had 3 leafs and 3 clips i think.
    2wd seems to get new packs with just an extra clip.
    4WD
    2WD
    FIXED WRONG INFO
  7. Mar 25, 2018 at 11:59 AM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    whats the recall?
  8. Mar 25, 2018 at 12:04 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Mine looked like that,I put in a Dakar Add A Leaf and it solved the problem,added about an 1 1/2 lift.
  9. Mar 25, 2018 at 12:05 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
  10. Mar 25, 2018 at 12:05 PM
    lynlan1819
    Tacoma
    Lifted
    Yeap he already has the new pack.
  11. Mar 25, 2018 at 12:06 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Not a recall, a TSB. Look at my previous post and if your pack looks like the red one on the 4wd one then you can go get two new leaf packs for free.
  12. Mar 25, 2018 at 12:07 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    It's to upgrade the packs that have 3 leaves to 4
  13. Mar 25, 2018 at 12:09 PM
    bangin4WV
    bangin4WV Well-Known Member
    Rocky
    WV.
    2016 SR5 2.7 MGM ACLB
    33s/sliders
    My 2016 with 17,500 miles look the same.
    Silentshredr likes this.
  14. Mar 25, 2018 at 12:09 PM
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    thanks for the info!
  15. Mar 25, 2018 at 12:14 PM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    Is this for 3rd gens as well?
  16. Mar 25, 2018 at 1:01 PM
    boudain
    Bobby
    South Texas
    With either of the replacements, do they handle loads well? I periodically need to haul dirt, mulch, and lumber. Perhaps it's time for a flatbed purchase.
  17. Mar 25, 2018 at 4:36 PM
    boudain
    Bobby
    South Texas
    Might be worth it for the heavier pack. Going to see what my options are at Toyota, first. Don't expect it, but I'll at least ask if it's warrantable.
    Blackout14 likes this.
  18. Mar 25, 2018 at 6:49 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I am unsure. I would assume toyota had the brains to put the 6 clip packs with 4 leafs into the 3rd gens.
  19. Mar 25, 2018 at 6:52 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Toyota will probably tell you to pound sand because you have the updated packs already and they will just run you around in circles, but you could try .. At this point i think its all on you, you wont regret an upgrade of the leaf pack if you use your truck as a truck. I have a 50$ AAL in my TSb 4 leaf pack because i cant afford a dakar pack or something yet.
  20. Mar 25, 2018 at 6:53 PM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Holy shit 3-4 inches of rear lift??? Got any picks of a 2nd gen with a 2" lift front and 4" lift rear?
