flex a lite bolt on electric fan intal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomonazul, May 27, 2012.
  1. May 27, 2012 at 7:59 AM
    tacomonazul
    tacomonazul [OP] Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    im installing this electric fan to my double cab Tacoma. im almost finish but i got sucked with the wiring. it says to connect a green cable to de a/c compressor. has someone already installed this electric fan? have same pics? help!:confused:
  2. May 27, 2012 at 7:54 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
    sub'd for a write up with pics! :)
  3. May 27, 2012 at 7:57 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
  4. May 27, 2012 at 9:42 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    where is a write up with pics??
  5. May 27, 2012 at 9:52 PM
    cdk
    cdk Well-Known Member
    san angelo,tx
    2012 PreRunner TSS
    BruteForceFab rear bumper, Ranch Hand front grille guard w/ led lights, leds here and there, seat covers, dash cover, console and handle covers, weathertechs, upgraded audio system, bed mat
    what fan kit are you installing?
    i've installed the flex-a-lite 180 on my previous truck and you run the green wire from the fan controller to a t-tap on the a/c compressor signal wire.
  6. May 27, 2012 at 9:57 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Op you got any pics of your progress
  7. May 27, 2012 at 9:58 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Lol they mean they're subbing this thread for you to post up a write up with pics :thumbsup:
  8. May 29, 2012 at 7:33 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I got a bit creative on this item on mine. I looked into the wiring diagram and tapped into the AC clutch wire inside the fusebox (engine fuse box) in order to protect the connection some. Sorry, no pics, but the wiring diagram in the on-line manual was what I used to find the correct wire in the fusebox, then I soldered the controller wire onto this wire and heat tubed and liquid taped it. I believe that the green wire that Flex wants you to tap into is on the drivers side down low by the compressor. I did not want to use a wire tap out in the open and down low for this as I figured in a year or two or three the connection would get bad.
  9. May 29, 2012 at 7:38 AM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    Keep us informed on how well it performs, especially in the heat under heavy load. I am thinking about doing this myself. I would prefer a dual fan setup if I can find one.
  10. May 29, 2012 at 7:44 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    Yes I think it would great if someone did a write up with pics. (Hint Hint) I have never been a fan (pun intended) of having the fan driven off of the motor.
  11. May 29, 2012 at 9:00 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Do some searching. I posted my own thread a while back (no pics) and have posted into several others on my opinions on the kit and whether it's worth it or not.
  12. May 30, 2012 at 2:18 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    I got installed it myself. I have been using it for almost 4 days, it performs very well even with the 120 Fahrenheit outside. The a/c works better with this fan, it comes out more air and very cold. It gives a little more power to the engine and better response.
  13. May 30, 2012 at 5:53 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    I've had this fan for a few months, it is conncected to just the battery with a temp guage to turn on when the engine is above 175, so it'll run even when the truck is off. It reduces the drag the clutch fan had on the crank, doesn't free up hp, but helps it get up to the rpm's quicker and smoother. Throttle response is improved also. I also have all the nst lite pulleys so i red line prettty quick in the auto when im gunning it. The nst pullies weigh usually less than half to your getting rid of a good 10lbs of extra weight your engine doesn't need to push around.
  14. May 31, 2012 at 10:46 AM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    Whats the cost of those pulleys im interested and did you installed them? do you need to change the band?
  15. Feb 11, 2017 at 1:14 AM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Any ever get pictures of the green wore to tap in ?
  16. Feb 11, 2017 at 7:07 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    I put one on my Tundra. I gained exactly 0mpg and didn't notice a difference in power. After blowing fuses and eventually frying the computer that's mounted in the most ridiculous spot(as per the instructions) instead of away from the heat where it has a chance.
    The bracket also rubbed on my lower radiator hose(not much room and all engines wiggle)which eventually rubbed through TWICE.
    I was sooooo happy to put the original fan back on and never have to worry about it again. :frusty:
  17. Feb 11, 2017 at 11:37 AM
    badger
    badger Well-Known Member
    07 SR5
    I have been building custom cars for 4 decades, and I have succumbed to this myself :facepalm:. I would never replace a factory fan with an aftermarket electric fan for these reasons:
    1. Even though they claim huge air flow numbers, almost none of them come anywhere close to the output of the factory fan. You will not realize you have a problem till the first time you head to the mountains on a warm summer day!
    2. NONE of them are built with the same reliability as a factory fan, and when they break, you won't find a new on at the corner NAPA.
    3. They are NOT free horsepower. Sure, they take some load off the crank, but the extra electrical draw loads down the alternator, which puts the drag right back on. The clutch fans on modern cars are extremely efficient, well designed items.
    Be smart and put your money into something really DOES work, like those little whirly "turbo" things for your tailpipe :burnrubber::D
