flex-a lite electric fan kit
Discussion in '4 Cylinder' started by racerdave, May 22, 2014.
  1. May 22, 2014 at 7:21 PM
    racerdave
    racerdave [OP] New Member
    Ohio
    base
    stock
  2. May 31, 2014 at 6:35 PM
    jjlmn
    jjlmn Member
    Jeff
    Minnesota
    14 Access Red OR
    These is a couple of threads on engine noise from the mechanical cooling fan. I think it's nuts that Toyota put a this in a 2014 vehicle. All about $ I would think , maybe its a reliability thing in extreme environments. Who knows , but I would love to get rid of that roar at start up.
  3. May 31, 2014 at 6:42 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    A group buy would be [​IMG]
  4. May 31, 2014 at 11:07 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Hey Dave, :)
    I'm also intrigued by that fan kit. My 2012 Toyota Yaris has electric cooling and it works great. I don't think anyone here has actually tried one on their 2.7, or even a 4.0 for that matter. But maybe someone has and can let us know how it works.
    Greg
  5. Jun 1, 2014 at 5:44 AM
    racerdave
    Ohio
    base
    stock
    Thanks for the reply's. I was thinking the other day I have an old flex a lite 2800cfm kit in my garage. I might pull in off the shelf and see what it looks like and if I can adapt it to fit. I know its a little smaller than the kit sold specifically for the truck, But as long as I can get 80% coverage I think I would be OK. I would need to build a bracket for the overfow tank too. Save myself some cash over buying the new kit. I don't care for the roar, and I know it would help out on economy and free up power. I'm OK with the power now, but I occasionally tow about 1200lbs with it and I think that is were it would really be nice.
  6. Jun 1, 2014 at 6:12 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    It's still common in the industry to use clutch fans for longitudinally-mounted engines. There is a temperature-controlled fan clutch, so parasitic losses are low. In addition to modern pickups, here's an example of a modern Audi with clutch fan:
    Modern BMW engine with clutch fan:
    The only real drawback to the clutch fan is less optimal A/C performance at idle. The Audi pictured has a separate condenser fan for this reason.
