Flex-a-lite wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lurkin, Aug 10, 2009.
  1. Aug 10, 2009 at 12:06 PM
    Lurkin
    Lurkin [OP] Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I bought the Flex-a-lite fan kit a while back and I'm just getting around to installing it. For those that have installed it:
    o where did you tap into the ignition and AC? (fuse/relay box, wiring harness, etc.)
    o how did you tap into the ignition and AC feed? (vampire wire tap, relay/fuse extension, etc.)
    Thanks, Rod.
