Flex Fuel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grey 2015, Mar 19, 2022.
  1. Mar 19, 2022 at 8:57 AM
    Grey 2015
    Grey 2015 [OP] Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Off topic but a friend of ours just topped off her Mazda 6 GT Turbo with flex fuel by mistake. What should she do? Check engine light has already come on I'm assuming due to the O2 sensor.
  2. Mar 19, 2022 at 9:28 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Have it towed to a garage and have them drain the fuel system, flush the fuel lines and replace any fuel filters. This is the only option that will not cause damage.
    Grey 2015[OP] likes this.
  3. Mar 19, 2022 at 9:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends how much she put in, if it was only a few gallons it should be fine just fill it with regular after it's down a bit. If it was a lot it would be a good idea to pump it out and put regular back in it.
    Almost all gasoline sold in the US has at least 10% ethanol so fuel systems are designed to tolerate it, the main difference between a flex fuel and non flex fuel vehicle is flex fuel vehicles have programming built in to change fuel strategies based on fuel composition since ethanol burns differently than straight gasoline.
    Non flex fuel vehicles are not programmed to handle running ethanol and will not run correctly on anything more than about 20%
  4. Mar 19, 2022 at 9:53 AM
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Yea she filled it from empty. The stealership is going to hit her up for $150 to drain the tank. Thanks for the tips guys!
    Dm93 likes this.
  5. Mar 19, 2022 at 10:04 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    At least it wasn't gasoline or DEF put in a diesel, that could potentially be a $10,000+ mistake.
    Lessons learned:thumbsup:
  6. Mar 19, 2022 at 10:07 AM
    HalfpipeKermit
    HalfpipeKermit Cat Herder
    VA
    2014 4WD 4.0 TRD Sport DCLB
    Had the self proclaimed genius at work do that a few months ago in the 2020 F250 super duty. It was right at 13k
    Dm93[QUOTED] and Grey 2015[OP] like this.
  7. Mar 19, 2022 at 6:22 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [ED] Entune Audio+ [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    IMO it's worth the money they want to drain the tank. Then the problem is gone before the computer goes even more biserk and starts throwing more codes to clear. A good chunk of that charge will probably the fee for disposing of the E85. Think of it this way: at current prices of unleaded, it would likely cost at least a C-note to fill the tank. A fill-up from 1/2 on my truck is easily $50-60 currently. 1/4 to fill-up is an easy $30.
    Grey 2015[QUOTED][OP] likes this.
  8. Mar 19, 2022 at 6:30 PM
    soggyBottom
    soggyBottom Well-Known Member
    I'm not an expert here this information may be incorrect. I remember something about rubber swelling in the presence on concentrated ethanol. Fuel systems that can higher concentrations of ethanol, don't use rubber seals. Again, this information may be wrong.
    wi_taco and racerX969 like this.
