flex seal
Discussion in 'Product Reviews' started by coffeesnob, Oct 27, 2012.
  1. Oct 27, 2012 at 1:02 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
  2. Nov 2, 2012 at 3:11 PM
    camelot142
    camelot142 Well-Known Member
    Brandon
    Southern California
    2002 Black Tacoma TRD
    Total Chaos Upper Arms, Kings Shocks
    ChadsPride likes this.
  3. Nov 2, 2012 at 9:41 PM
    DPCardoza
    DPCardoza Well-Known Member
    Yuba City
    06 PreRunner Sport Long Bed
    I'm an ICU nurse and flexi seal is a "fecal managment system". I initially thought we were reviewing these. Seemed kinda strange, but was curious what you thought.
  4. Nov 2, 2012 at 9:44 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Substitute for plasti-dip or bed liner maybe???
  5. Nov 3, 2012 at 5:40 AM
    coffeesnob
    VA
    nothing.... I saw the commercials on tv for it and thought it might be handy to have a can on hand for any reason.
    inwood customs and ChadsPride like this.
  6. Nov 3, 2012 at 5:43 AM
    coffeesnob
    VA
    well I guess you could use flex seal for that just seal everything up no muss no fuss
  7. Nov 11, 2016 at 7:12 PM
    Coma Rookie
    Coma Rookie Well-Known Member
    Mr.
    Alaska
    02 DC TRD *SOLD for $18k*
    More than I can shake a stick at...
    I know this thread is old, but I keep some in the ammo can of goodies on long hunting/camping trips in case I need to "temporarily" repair a cut CV boot. I used it once to temporarily seal an inner boot that was cut until I found the time to use my lifetime warranty on my axles;). I refuse to ever replace a boot again, major PITA! It held up for a few weeks but I wouldn't trust it long term. FYI I cleaned the boot 1 rib over in each direction with denatured alcohol to allow for a good mating surface.
  8. Dec 3, 2016 at 8:57 AM
    UncommonLife
    UncommonLife Well-Known Member
    Alan
    Salida, CO
    2009 TRD Sport DCSB
    Used this stuff to fix holes in a corrugated roof. Works fine, but not much better than any competitors product. The black worked better than the clear
  9. Dec 3, 2016 at 10:52 AM
    tkn
    tkn Well-Known Member
    Seattle
    2014 Tacoma TRD Sport 6spd
    Full Icon Stage 4 Lift w/ OME Dakar rear spring
    kinda overrated but does what its meant to do.
  10. Nov 6, 2017 at 10:00 PM
    kodaco771
    kodaco771 Well-Known Member
    So Cal
    2017 OR DCLB 4x4
    6112/5160's & Wheeler's Progressive 3AAL SCS SR8’s
    I sealed a cheap tool box on my work truck to prevent water from seaping in from underneath. It has worked great so far but it was a little more expensive than I expected.
  11. Jul 26, 2019 at 9:18 PM
    TacoAdmirer215
    TacoAdmirer215 Active Member
    Nick
    Philadelphia, Pa
    2018 Tacoma TRD Sport DCLB
    Toytec BOSS suspension ALUM series
    Anyone use this for after cab mount chop care like on the pinch wield ?
  12. Jul 26, 2019 at 9:19 PM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Yep we use it and we have done 50.
  13. Jul 26, 2019 at 9:28 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    True story :anonymous: I once worked in a circus tent it wasn't a real circus, but a circus none the less. This tent had a steal frame and water would come up under the bottom of the frame into the tent. Some of the performers would complain to the manager. One day the manager comes out and sprays a can of flex seal around the area where the water gets in. You can't stop gravity with any thing found in a can, but I commended the manager for trying to do something instead of nothing.
    Gus87 likes this.
  14. Jul 27, 2019 at 3:53 AM
    TacoAdmirer215
    Nick
    Philadelphia, Pa
    Recommended or use something else?
  15. Jul 27, 2019 at 6:29 AM
    Jason TRD OR
    Works great to seal pinch weld
  16. Jul 27, 2019 at 6:30 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    FlexiSeals are one of the most incredible tools to our disposal as nurses. Getting one to not leak whatsoever isn’t always as easy.. but can be done.
  17. Jul 28, 2019 at 4:02 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Apparently you can make a boat out of it
