flexible thin short antenna
Discussion in 'Audio & Video' started by builthatch, Feb 16, 2011.
  1. Feb 16, 2011 at 11:02 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    ok, so it seems the following is true:
    - any of the short antennas that are thin like the OE one are not flexible. they break and can even mess up the base if hit hard enough. no good for me.
    - the only flexible antennas are fat vinyl antennas - unattractive imo.
    i read ONE post in one of the threads of my research where a guy heated the end of the OE antenna and pulled the ball off, cut the stocker to the height he wanted, and with the end a little hot he put the ball back on and it sealed back up. that sounds ideal to me but i can't verify it.
    any other options you guys are aware of where i can get a flexible and thin short antenna? i'd say 14" would be ideal, about roof height, or really short...anything in between looks weird.
  2. Feb 16, 2011 at 11:13 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    you will only loose reception.
  3. Feb 16, 2011 at 11:17 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i'm not concerned as i only listen to sirius radio. the OE antenna length makes it so i have to affix vice grips in the track of the garage door to keep it from hitting each and every time i want to move the truck in and out of the garage. i'm sick and tired of doing that. the truck clears just fine with several inches to spare. the antenna is the thorn in my side.
  4. Feb 16, 2011 at 11:20 PM
    S.B.
    Sean
    Then completely remove the antenna and put plug un the base so it doesn't rust out.
  5. Feb 16, 2011 at 11:44 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    thanks. asthetically that doesn't please me. that solution looks like the antenna broke and the base is left. if it was "shaved", that would be different.
  6. Feb 17, 2011 at 7:18 AM
    AbqTRD2010
    AbqTRD2010 Well-Known Member
    Michael
    Rio Rancho, NM
    '10 4x4 DblCab Long Bed Sport
    TRD FJ TeamTrail Blk Rims| BFG AT KO 265/75/16| TRD Cat-back Exhaust | TRD CAI | UNICHIP Installed| 5100 Billies @ 1.75 | Rear Leaft TSB & 1" Block| Grillcraft Satoshi Grill | Exclusive Element Light Bar w/ Hella 500FF | Aftermarket Black Headlights & Black LED Tail Lights| Preimium Hook Struts | SungTop LS Tonneau Cover |Black OEM Running Boards | Window Tint @ 20%| Blacked Out Emblems| Shortened Antenna | Flyzeye LED Interior Accent Lighting
    I also removed the ball from my antenna, cut to desired length (roof line height) and placed the ball back on. I found a post on here that showed how to easily remove the ball. Place a set of pliers just behind the ball and tap the pliers with a hammer. This prevents you from trying to pull the ball off and scratching the ball. If you try to pull the ball off, it is near impossible and made of a soft metal that will easily leave deep scratches. It will take a few taps to knock the ball off. Make sure you are tapping the ball into a confined corner so you can find it when it comes off.
    Cut the antenna to the desired length. The cut location I chose was low enough that the antenna was thinner than the hole of the ball. To make sure I had a good fit and a clean finish I used the dermal to sand down the tip of the antenna and the black from the tip of the antenna. I filled the ball with solder and quickly placed back on the antenna. I used some extra solder around the bottom of the ball once it was placed on the antenna to ensure a tight fit. Then sanded down the solder to give the ball and the antenna a smooth finish. Finally I used flat black paint to repaint the antenna.
    The ball is nice and tight on the antenna. Also the antenna is now to a desired height so it no longer hits my garage door when driving in. I have not had any reception with any of the main local stations. There are a couple stations that I get very little static now when going under a bridge, in parking garages but no complaints about looks or reception.
    I intially bought one of those thick shorty antennas and I didnt like the look and also got a decent amouth of static.
  7. Feb 17, 2011 at 7:36 AM
    zabstaCOma
    zabstaCOma Well-Known Member
    Nate
    Colorado
    2012 toyota tacoma TRD off road
    -debagged -shorty black antenna 14'
  8. Feb 17, 2011 at 8:33 AM
    jdtemple
    jdtemple Well-Known Member
    Bay Area CA
    08 DBLCAB LB TRD Sport
    Lift & Tires, in cab power outlets, Locking Bed Boxes, K&N
    Having that antenna hit the roof of a parking garage first is better than having the cab hit it. If you use parking structures, I would leave it as is. The antenna hitting is the first sign clearance is tight.
  9. Feb 17, 2011 at 9:19 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    dang, thanks!!!
    that is a very good point as it is indeed a built in height check. but for me, i only park my truck in my garage. i haven't parked any of my personal cars in anything but my garage, ever! my wife's cars, yeah, but mine typically stay home or i will insist on a street/lot spot.
  10. Feb 17, 2011 at 3:39 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
  11. Feb 18, 2011 at 7:36 AM
    zabstaCOma
    Nate
    Colorado
    is it springy like the OE one? that site says it's made out of aluminum
    Tony
    Here is the same one i have the 14 inch black. It is a springy but since it is so small there is a point where you cant bend it anymore. I love it it makes the truck look better (my opinion) does not hit the top of my garage when i pull in, works as good as the stock one still get al the radio channels with clear reception. Would refer to a friend. Hope this helps
    http://www.shortyantennasource.com/index.php?main_page=index&cPath=8_57
  12. Feb 18, 2011 at 7:46 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i pulled the ball off, cut it down to clear the garage opening and put the ball back on, no reception problems
  13. Feb 18, 2011 at 8:00 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  14. Feb 18, 2011 at 7:38 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    in for more info on any of the thin antennas IF they are flexible like stock. thanks.
  15. Feb 18, 2011 at 7:42 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    ^^ Me too...I got an Antennax for Christmas and it made it through two car washes before it was fup duck. I took my stock and cut about 8-10" off of it and super glued the ball back on and it looks pretty cool. Reception seems to be about the same but like some others I'm an XM guy so don't listen to terrestrial radio much. That's what I'd do...
  16. Feb 18, 2011 at 7:50 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    yeah, i'll probably go that route. i just hate cutting things unless i have an original to replace it with. i'm super careful and precise but just hate permanently modifying stuff on new vehicles, lol. i know, it's crazy.
  17. Feb 19, 2011 at 4:58 PM
    brumbyvet
    brumbyvet New Member
    East Tennessee
    08 SR5 4X4
    I've done this on many vehicles including my Tacoma and it's very easy to do and looks good. Just remove antenna from truck, cut it at whatever length you want and then dip the cut end into a can of black liquid electrical tape. I usually cover about 3/4 inch of the antenna end and apply three coats. It holds up very well, even in the carwash, and looks professional. You can find this black liquid electrical tape at any auto parts store or even walmart and it's not very expensive.
  18. Feb 25, 2011 at 5:12 PM
    BLACKnBLUE
    BLACKnBLUE Well-Known Member
    Iain
    Ellensburg, WA (Kittitas County)
    07 TRD SR5 with ARB Front Bumper
    ARB front winch bar, 3" lift, blacked out badges, blacked out headlights, Custom Steel Rear Bumper Mod, and Leer 100XQ
