Flexing pics
Discussion in 'Off-Roading & Trails' started by usctacoma, Jun 5, 2009.
  1. Dec 10, 2013 at 11:23 PM
    #3281
    cadeo1
    cadeo1 New Member
    cade
    new zealand
  2. Dec 10, 2013 at 11:26 PM
    #3282
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    doesnt necessarily mean more travel, just means it's higher to begin with
  3. Dec 11, 2013 at 7:09 AM
    #3283
    steezemcqueen
    steezemcqueen 4Runner Abuser
    Dylan
    Crawlarado
    1997 4Runner Turbo and 2006 Tacoma
    Unicorn fart injection system
    Correct but it will still compress to the same point as it did without the shackles. Thus, more travel.
  4. Dec 11, 2013 at 8:26 AM
    #3284
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Not if the leaf pack doesn't allow for it. Sure you can get more travel if you let the pack go negative arch and fuck it into early retirement.
    Shackles are supposed to be used for one thing....and it's not to add travel or lift. Leafs change in lateral length, shorter at droop and longer towards bump. The sole responsibility of a shackle is to accommodate the change in lateral length. If you're using them for anything else, it's a band-aid and isn't going to help you one bit and will beget other problems.
    Aside from that, leaf springs are not just springs they are also what locates the axle, side to side and front to back. While driving, accelerating, braking, turning or articulating the rear axle wants to flop all over the fucking place. The only thing stopping that is the spring. Now think of the spring as a giant lever magnifying all that force into the hanger. Travel isn't the problem (the shackle pivoting soaks that up) its the side load and twisting action that the shackle and pivot get subjected to that starts breaking parts. Longer shackles only magnify it.
  5. Dec 11, 2013 at 8:33 AM
    #3285
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    False. Teraflex Revolvers.:stirthepot: I know you were referring to longer shackles, not revolvers, thought I'd make that clear.
  6. Dec 11, 2013 at 8:38 AM
    #3286
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    LOL....touche.
  7. Dec 11, 2013 at 12:04 PM
    #3287
    BradyT88
    BradyT88 Well-Known Member
  8. Dec 11, 2013 at 3:12 PM
    #3288
    Manwithoutaplan
    ID
  9. Dec 11, 2013 at 3:24 PM
    #3289
    BradyT88
    Where's the flex?:confused: ;) haha
  10. Dec 11, 2013 at 3:25 PM
    #3290
    Manwithoutaplan
    ID
  11. Dec 11, 2013 at 3:26 PM
    #3291
    Boone
    Boone, NC
    Airbags deployed
    I thought the same thing.
  12. Dec 16, 2013 at 7:40 AM
    #3292
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    some RTI action from an off road event this weekend.
  13. Dec 16, 2013 at 8:25 AM
    #3293
    BradyT88
    So is that kind of a strategy? All of you guys hit it at the same angle kind of turning into the ramp so you are almost sideways on it. Kind of how the car is on it. Is that just to help keep from rolling as you get higher up it basically?
  14. Dec 16, 2013 at 8:29 AM
    #3294
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    you hit it as straight on as possible. only reason to hit it at an angle is if you have enough articulation that a straight on shot would have your rear tire climbing on it before you max out. you're only going to flip if you go up way too far and 3-wheel it. the car is liek that because he turned into it last minue when he saw us looking at him and pointing at the ramp lol.
  15. Dec 16, 2013 at 8:32 AM
    #3295
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Almost drooped out, shackle still hadn't fallen forward, still a couple inches to go.
  16. Dec 16, 2013 at 8:35 AM
    #3296
    BradyT88
    I see. Looking at those pics it doesn't look like hardly any of them hit it straight on though. None of them are as angled as the car but some appear to be angled though. Maybe it's more camera angle than anything. Haha
  17. Dec 16, 2013 at 8:41 AM
    #3297
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    probably a lot of camera angle. it was pretty tight with some of the other show vehicles parked near the ramp though, so i'm sure none of us were centered. luckily the angle at which you hit it won't throw off how far up you make it.
  18. Dec 16, 2013 at 9:12 AM
    #3298
    BradyT88
    Did you guys manage to squish your front bump pretty good before you started to lift a tire off the ground? I was wondering if being angled like that would help put more weight on that front tire on the ramp helping it stuff better since IFS doesn't like to stuff as well as solid axles do when crawling.
  19. Dec 16, 2013 at 9:24 AM
    #3299
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    :thumbsup:
  20. Dec 16, 2013 at 9:28 AM
    #3300
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i fully load my front bumps no problem. i sit low enough that it doesn't take nearly the same force to fully compress the front end. the guys sitting on 3'' of lift don't typically make it up as far because there isn't enough weight on the front end to utilize all of the front travel in a static situation.
