Flexplate issues 2001 3.4 auto
Discussion in '1st Gen. Tacomas (1995-2004)' started by ebayollis, Sep 24, 2016.
  1. Jun 26, 2021 at 10:50 PM
    Turnthecherryout
    Turnthecherryout Member
    2000 Toyota Tacoma prerunner TRD
    346xxx
    I know this is an old thread but I’ll be replacing my flex plate soon. Do I need to get new bolts for it or do I need anything else other than the flex plate I bought at the junkyard today? Also the used one I have has some surface rust should I try to clean it? Do I not want any oil or grease on the flywheel?
  2. Jun 26, 2021 at 11:22 PM
    gearcruncher
    Canadain bumper technician
    How is the rear main engine oil seal ?
    How is the front transmission pump seal.
    Will you be draining the trans fluid ?
  3. Jun 27, 2021 at 12:03 AM
    Turnthecherryout
    346xxx
    I was hoping not to but I’m not sure I haven’t found any good write ups yet. I think the rear main is good. I haven’t had any leaks or oil loss but I’m at 346k so maybe I should. I talked to a mechanic about it and he said if the seal is good. I may be opening a can of worms. My issue was I started it knowing the the starter was a failing. So when it finally did it came out in pieces I had a bunch of ball bearings come out of the inspection plate. I replaced the starter and tried cleaning up the inspection area blew it out with air. The new starter was working fine for a year until a few weeks ago it wouldnt start it got stuck and sounded like it did the when the starter went out. I pulled the starter of a another ball bearing came out with the starter but otherwise it looked fine. I replaced it anyway since it was under warranty. After I replaced it, it was still suck I turned the engine over manually 180 on the pulley and it started. It’s been starting since but I turned it and inspected the flexplate it’s a chewed up a little but it’s missing a couple teeth. And that’s why I’m replacing it. Thanks for any advice.
