Flexplate keeps cracking - 02 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Silver_Taco_106, Mar 26, 2017.
  1. Mar 26, 2017 at 2:04 PM
    Silver_Taco_106
    Silver_Taco_106 [OP] New Member
    2002 Tacoma SR5 4x4
    Alright yall this is my first post but I would appreciate some help on this one.
    I have an '02 Tacoma SR5 w/ the TRD Off Road package. About a year and a half ago, the flexplate cracked and had to be replaced. Every 8 months since then, like clock work, it has been cracking. I'm now getting ready to replace it for the 3rd time. I'm thinking whatever issue caused this to happen the first time, has never been solved by either mechanic I took it to.
    Do any of you have suggestions on what the issue might be or have you had experience with this kind of problem? Any help is much appreciated.
  2. Mar 26, 2017 at 5:26 PM
    ZUK
    ZUK Gearinstalls.com
    Ken
    Chandler AZ
    2001 white Taco TRD 3.4L auto (SAS FJ60 flip) 35" KO2 5" AllPro leafpacks front and rear,
    SAS,1985 FJ60 flipped axle, 35" KO2,5" AllPro leafpacks front and rear,
    Something is shock loading the flexplate maybe? Does the tranny has a "shift kit" in it which would firm up the shift points and might transmit a shock wave into the plate every time it slams into another gear. Best solution, no matter what the cause, might be to cryo treat the flexplate.
    Wyoming09 and Speedytech7 like this.
  3. Mar 26, 2017 at 5:30 PM
    Clearwater Bill
    Billy
    Largo Florida
    Torqued in a bind during installation?
  4. Mar 26, 2017 at 5:34 PM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    How's the starter? Does it hang up and the solenoid maybe doesn't retract the starter gear back in. Maybe jamming the flex plate?
  5. Mar 26, 2017 at 7:15 PM
    gearcruncher
    Canadain bumper technician
    Missing dowel pins , bellhousing run out , crankshaft end play , loose bellhousing bolts . bad universal joints , broken transmission mounts , incorrect flex plate used , missing flex plate shims . incorrect assembly as mentioned above by Bill .
    Converter pilot shaft broken and stuck in crankshaft
    There are all kinds of issues that come into play here . How does the transmission upshift and downshift ? Any vibrations ?
    Wulf, 45acp, Wyoming09 and 3 others like this.
  6. Mar 27, 2017 at 5:09 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Good to know about this issue. Any idea of they can be treated for added strength, since it seems I can't find any aftermarket options?
  7. Mar 27, 2017 at 5:48 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Like Bill mentioned, there is a proper torque sequence to follow to tighten the flex plate to the crankshaft. And like gearcruncher said, the flex plate does have a spacer/shim and maybe they didn't install it. There's also a chance they didn't gradually torque the bolts that hold the flex plate to the torque converter and maybe it's not balanced. I helped my buddy Sean replace his auto trans recently and I gradually tightened the flex plate/torque converter bolts to spec in many passes as Sean turned the crankshaft bolt for me. When it's not balanced and has a ever so slight shimmy to it, it's eventually going to fatigue and break. But, like gearcruncher mentioned, that movement could be caused by other things as well.
    Wyoming09 and Pickeledpigsfeet like this.
  8. Mar 29, 2017 at 11:28 PM
    Silver_Taco_106
    2002 Tacoma SR5 4x4
    10tacosr5
    The first time I replaced it, didn't notice anything from the starter. Now this last time it was replaced it started making this screeching grinding sound every time you start it. Its been doing that the last eight months since then.
  9. Mar 30, 2017 at 10:25 AM
    Timmah!
    TIM
    It sounds like the starter gear isn't lining up right with the drive plate gear (aka Flex plate gear). Is your starter an OEM Denso starter or is it an aftermarket replacement? I'd check to see if the starter is fastened tightly to the bell housing. If the starter is OEM and tight to the bell housing, something isn't right. You should not be hearing a grinding noise. When you got your rig back after the last drive plate replacement and noticed the grinding noise every time you started it, did you go back to the shop and ask what's up? If the mechanic didn't install the front drive plate spacer (this is the one between the drive plate and crankshaft) this would put the flex plate in the wrong position. There's also a chance he swapped the spacers. The front spacer between the crankshaft and drive plate is different from the rear spacer that goes between the bolt heads and drive plate. Whether the front spacer is missing or the wrong one could explain why the starter gear is meeting up right with the drive gear.
    I looked up the parts numbers:
    The front spacer for a V6 is #32116-32020
    The rear spacer for a v6 is #32117-50010
    Here's a link to a parts seller where I figured this out:
    http://parts.lakelandtoyota.com/sho...&ukey_driveLine=6762&searchString=drive plate
    VZN18# is for V6 engines and RZN18# is for 4 cylinder engines.
  10. Aug 11, 2020 at 11:28 AM
    Silver_Taco_106
    2002 Tacoma SR5 4x4
    A bad torque converter turned out to be the problem. Hasn't happened again since we replaced it!
    45acp, cruiserguy and Ccrowe323 like this.
  11. Aug 12, 2020 at 1:00 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Good to know just what the cause was
    cruiserguy likes this.
  12. Aug 12, 2020 at 6:03 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Awesome to hear man!
    As I was re-reading the posts above asking about that and the different replies and after seeing ZUK suggestion of something shockloading the flexplate, the torque converter popped into my head.
    Glad you reported back and glad it's up and running the way a first gen taco should be:cool:
    Wulf likes this.
  13. Aug 12, 2020 at 11:28 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I saw the date and was bummed I couldn’t answer you. I had the exact same problem, my torque converter was warped. The shop used a runout gauge and it was completely messed up and uneven, like a valley.
    For my second flex plate I made it a whole 200 yards from the shop before it broke again
    cruiserguy and Wyoming09 like this.
