flickering again....
Discussion in 'Lighting' started by zx6rman96, Apr 25, 2011.
  1. Apr 25, 2011 at 3:21 PM
    zx6rman96
    zx6rman96 [OP] Well-Known Member
    Indianapolis
    07 PreRunner SR5 TRD off road
    JVC HD-60 tinted windows Black paitned TRD wheels 6000k Bi Xexon HID's Laminx yellow (fogs's) Rear TSB
    Wow, 2 ballast and a replacement bulb after only 3 or 4 months and i still have problems with my HID's. My passenger side and sometimes drivers side wants to flicker while I'm driving. Sometimes they will stay on no problem, other times they dance all over the place. I am so fed up with emailing the vendor on getting replacement parts, I just want my dang lights to work!!! I have a simple plug in play setup, there is no relay to the battery as I have seen some setups use this. I am thinking this might be a problem. I've seen some anti-flicker harnesses out there, dont know if thats what i need. Anyway, anyone have any suggestions for a fix....or a reputable brand or vendor i can get some lights with out all this hassle? I wont mention who I brought them from because he's warrantied my bulb and ballast, so it's not his fault, just the dang company he's getting them from I'm thinking......
  2. Apr 25, 2011 at 3:24 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    All the plug-n-play setups I've seen require a relay to the battery to work correctly. There was another TW member on here that had no relay and she would get the same kinds of problems as you. Then she got a relay harness and they worked fine after that.:cool: I'm not an HID expert but I would say you need a relay harness to the battery.
  3. Apr 25, 2011 at 3:25 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Mine used to flicker, but realized I had a poor ground. Fixed that and never had problems since
  4. Apr 25, 2011 at 3:35 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Do you have a relay harness?
  5. Apr 25, 2011 at 4:23 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    WOW I thought mine was a special case.. I've never heard of this flickering thing happening before... What causes that?
  6. Apr 25, 2011 at 4:24 PM
    MJonaGS32
    MJ
    SF Bay Area (East)
    yes
  7. Apr 25, 2011 at 4:39 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Relay harness has nothing to do with it. check grounds and power connections. relay harness' are only needed for Hi/Lo setups. The factory wiring is more than enough to handle the load of HIDs without a relay harness. If you check all your grounds and power connections and if they are still messed up then i highly suggest you junk the cheap Chinese HIDs and spend the money on a decent set.
    Cheap HIDs are just that... CHEAP. Some times they can be decent, sometimes not. It is real hit or miss. Look for the German Klight brand. excellent HID kits.
  8. Apr 25, 2011 at 5:39 PM
    zx6rman96
    Indianapolis
    I do have bi xenon...(hi/lo) setup... I've check most of the grounds i could find, are there any others....what sort of power connetions are you talking? The HID kit is pretty simple, even a caveman could do it..HAHA its all color coded, pretty hard to screw it up. Im not sure if it's a chinese kit or not. I got them from a group buy on here, havn't really heard of anyone else having problems, but then again maybe they ditched there's a long time ago when i was having problems too.
  9. May 31, 2011 at 1:38 PM
    runyun
    runyun Well-Known Member
    Irving/N. Grand Prairie
    02 Silver TRD DC
    I have the same issue. Mine are Xentec (slim design brand)
    No problems with the 6k bulbs, but when I replaced them with the 5k bulbs.. they flicker all over the place.
