flimsy door panel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by reptile savvy, Aug 25, 2016.
  1. Aug 25, 2016 at 9:44 AM
    reptile savvy
    reptile savvy [OP] Member
    don't you guys think driver's side door panel is so flimsy?
    when I roll up window of driver's side all the way, the whole door panel gets pushed against my left knee. When I took my truck to dealer for transmission TSB, I showed it to worker (I don't know if he was a mechanic or not) said that it's normal, said "it's a motor".
    My 2005 corolla's door panel is way more sturdier than 2016 Tacoma, the door panel doesn't get pushed against my left knee when I roll up window all the way.
    Does anybody noticed a same issue?
    Am I the only person concerned about this?
  2. Aug 25, 2016 at 10:05 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Might be more pronounced to you since you're touching it, but it's normal so far as I have ever noticed on previous vehicles. It might be a flimsier panel, too.. there are sacrifices made when trucks are targeting MPG goals, and weight cutting of plastic parts and body panels is where it's done.
  3. Aug 25, 2016 at 10:06 AM
    Shaunsquatch
    Shaunsquatch Well-Known Member
    Shaun
    Louisville, KY
    2020 Tundra
    I haven't had a vehicle that the door doesn't "swell" when the window is all the way down or up.
  4. Aug 25, 2016 at 10:07 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Normal. They all do it. I don't see it as an issue. And the weathstrip on top moves when the window touches it.
    Traction likes this.
