Flippac from Ford Ranger
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mojave4x, Jun 20, 2019.
  1. Jun 20, 2019 at 7:21 AM
    Mojave4x
    Mojave4x [OP] Active Member
    98 SR5 4x4 extended cab 3.4 5speed & 08 limited 4Runner 4x4 4.0
    Detroit TrueTrac both diffs, re-gear 4:30, Wheeler's 8 leaf, OME 881, JBA UCAs, Bilstein 5100 all 4 corners, All new u-joints & ball joints, new LCA bushings
    I'm about to purchase a FlipPac that was on a 95 Ford Ranger. I measured bed/shell width, cab height and bed/shell length and I believe it will fit on my 98 taco access cab.
    My concern is the width, the ranger inside bed width is 54.5"
    Taco minimum inside bed width is 57", the max is 60" - so the bed "rail" is 3" wide.
    The FP minimum inside width is 59", the inside max is 63" - "rail" is 4" wide.
    It seems there would only be 1" to fit the FP on.
    My question to FlipPac owners is this: anyone fit one from a mid to late 90's Ford Ranger, onto to a 1st gen? What installment or fit issues (if any) did you have?
    If you could reply soon that would be great, I don't want to let this get away if it will fit.
    Thanks everyone!
  2. Jun 20, 2019 at 9:15 AM
    Taco!
    Taco! Well-Known Member
    98Xcab4WD
  3. Jun 20, 2019 at 8:34 PM
    Mojave4x
    I didn’t get a chance today to look but only briefly, looks like a ton of info. I’ll try tomorrow, thanks
  4. Jun 27, 2019 at 5:26 AM
    Mojave4x
    I decided not to buy it, I didn’t like the cracks in the fiberglass around the torsion bar. It could be nothing, could be structural damage - I really don’t know.
    I put the link below if anyone is interested $2100
    https://offerup.co/uWenhMYpRX
  5. Jun 27, 2019 at 5:36 AM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
  6. Jun 27, 2019 at 5:41 AM
    FreshOldTaco
    FreshOldTaco Well-Known Rider
    kevin
    2003 Tacoma
