Flipping an exterior opening door for security door install
Discussion in 'Garage / Workshop' started by Sublime, Jun 2, 2013.
  1. Jun 2, 2013 at 9:01 PM
    Sublime
    Sublime [OP] Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Alright handy fellas,
    I'm going to install a couple security doors this week and one the the main doors opens out (exposed hinges). I know I need to flip the hinges by chiseling out new spots on the inside and just flip the door but not sure on how to make new holes in the frame for the door knob/deadbolt....spade bit? Looks like the door stop isn't centered perfect either so i guess that needs to be removed and re-installed in the right spot? I've just never done anything like this before.
    With the other door, it looks like I will need to hack away some of the stucco to expose more of the frame for mounting. What's the best way to go about doing that without chipping too much away?
    Thanks for the help!
  2. Jun 2, 2013 at 9:10 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why do you need to flip the door ?
    because the hinges are on the outside ?
  3. Jun 2, 2013 at 9:12 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Ya!? I'm confused?.....
    Brett
  4. Jun 2, 2013 at 9:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Catch 22
    Inward opening doors are easy to kick open.
    Outward opening doors (common in Europe BTW) are harder to kick open, but the exposed hinges are an issue if the intruder has time to work them (and an uninhabited shop, yes, they do).
    Solution?
    Keep the exterior hinges, but install 4 deadbolts, 2 on each side.
  5. Jun 2, 2013 at 9:18 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I'm installing security doors.....the heavy duty steal ones and I can't with the door attached to the outside frame. The security doors are made to install on doors that open to the inside and the steal door will open out. Unless I'm wrong?
  6. Jun 2, 2013 at 9:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You'll need a new door frame if it's a standard wood door/frame with weather seals.
    Do you really need the "security" door, or would more deadbolts not be sufficient?
  7. Jun 2, 2013 at 9:24 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    It's a glass door so it needs the exterior one. Also a condo and that's what they want us to do. They're actually nice most of the year for the cross breeze.....just not in the 115* summer!
  8. Jun 2, 2013 at 9:41 PM
    OZ-T
    Peter North
    British Columbia
    Or install NRP hinges
  9. Jun 3, 2013 at 5:15 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Nobody??
  10. Jun 3, 2013 at 6:32 PM
    OZ-T
    Peter North
    British Columbia
    I honestly don't understand the question
    If you are replacing the door , remove the entire jamb and replace with a prehung door that has a correct swing
  11. Jun 3, 2013 at 6:37 PM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Sounds like he's adding a security door (sort of like a storm door) on front of the existing door and the outswing door is in the way of installing it.
  12. Jun 3, 2013 at 6:41 PM
    OZ-T
    Peter North
    British Columbia
    Sounds to me like he's adding a security door so the existing outswing door needs to become an inswing
    If that is the case cut out the whole jamb and replace it with a door that swings and is weatherstripped correctly
  13. Jun 3, 2013 at 6:45 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    This ^^
  14. Jun 3, 2013 at 7:52 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Hole saw..will make a beautiful round hole. Goes right on a drill..my advice is use an electric drill so you don't lose torque if it's a tough cut.
    I had to do it on one door at my house..and more recently for the deck to install my pool ladder.
    It will have a round saw that is somewhat cup-shaped and in the middle will be a drill bit to get you started.
  15. Jun 3, 2013 at 8:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup.
    The door can be reused, but the jamb can't.
    At least the new frame will hide the existing notches for the hinges. Door will look bad when it's open unless they are filled and smoothed.
    But if it's an expensive door, then it may be worth reusing.
  16. Jun 19, 2013 at 7:20 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    i'm not a fan of spade bits, ...i think forstner bits are better....
  17. Jun 19, 2013 at 9:04 PM
    OZ-T
    Peter North
    British Columbia
    Depends what you are doing
