Flipping dip stick SUCKS!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tommy, Jun 26, 2013.
  1. Jun 26, 2013 at 4:15 AM
    Tommy
    Tommy [OP] Well-Known Member
    Tom
    Indiana
    2010 Access cab SR5 4x4
    Just want to say again how much the damn dick stick on this truck sucks ass! I mean come on, its virtually impossible to check the engine oil level!!
    I did sand some criss cross lines on it and that helped a little but not enough. So, really the only way I know how much oil is in there is when I do a change. What happens if I have a leak or start to burn oil, I'll never be able to know how much to add. FRUSTRATING! Anybody ever come up with a good solution to fix this worthless piece of steel?
  2. Jun 26, 2013 at 4:22 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I have not done it yet to this veh but in the past I have done as you. I filed a line perpendicular to the stick to hold the oil, just don't go so far as to weaken it. And clean it good before reinstalling it
  3. Jun 26, 2013 at 7:24 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    pull the dipstick out - let it sit for a few hours our of the tube (i usually let it sit overnight) then shove it back in now that the tube is dripped dry and you will get a nice accurate reading
  4. Jun 26, 2013 at 7:38 AM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    Try using a sharpie to blacken the area. Clean with brake cleaner first.
  5. Jun 26, 2013 at 7:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2. This works with the dip stick in place also. I usually let my truck sit overnight and check it before I fire it up to go to work in the morning.
  6. Jun 26, 2013 at 7:40 AM
    DirtEater
    Surprise, AZ
    It is hard to see when you first change the oil, but after it turns from honey to a light brown it starts to show up better.
    You might also use Royal Purple oil. Shouldn't have a problem seeing it then.
  7. Jun 26, 2013 at 9:08 AM
    Tommy
    Tom
    Indiana
    Thanks for the tips! Though I still think Toyota could come up with a better stick than this, both my other vehicles have cable type sticks that work very well. I wonder if there is any aftermarket sticks made for Tacos. I'll have to do some searching.
  8. Jun 26, 2013 at 9:36 AM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    Drill a very small hole, right on the line. Easier to see. When you remove the dipstick, wipe it off before reinserting, and that will help eliminate false readings.
  9. Sep 27, 2013 at 10:01 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I just bead blasted the lower 1/3 of the stick it seemed to have helped a little.
  10. Sep 27, 2013 at 10:49 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    They do suck. The only real way seems to be to let it sit for a while and let it settle. It seems that the oil travels up the tube and gets on the stick after the first pull. Very annoying.
