Flippy02's Ball Joint Flip Adventure
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flippy02, Apr 30, 2020.
  1. Apr 30, 2020 at 5:20 AM
    Flippy02
    Flippy02 [OP] Well-Known Member
    Central Coast, CA
    1999 Black Tacoma Base
    Upgrading with stock options
    Decided to make use of my extra free time during this shelter in place and got myself a DJM 3/4 kit, energy polyurethane suspension kit for the rear end, swapped out to 01-04 leaf spring shackles to make them work and removed the Daystar leveling kit up front. I already had pre-runner rear leaf springs installed on the rear, that was before I knew there was such a huge difference between models.
    I also decided to polish the headlights using a kit from Cerakote, seemed to work pretty well and I would recommend it. I only regret not taking before and after pictures.
    I did have a pretty good taco lean while, so while I was at it, I swapped the front and rear springs from the driver side to the passenger side and that seemed to help a little a good amount.
    This also took me way longer to do then it should have, but overall I'm pretty pleased.
    Once I get my seatbelts back from getting new webbing installed, I'll get aligned and a proper break in.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    TForan, po35042, defythemall and 3 others like this.
  2. May 4, 2020 at 7:38 PM
    PrerunnerVsix
    PrerunnerVsix Well-Known Member
    Ali
    Houston, Tx
    2013 Tacoma TRD Sport
    looking good man
    Flippy02[OP] likes this.
  3. May 4, 2020 at 10:48 PM
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
    Exactly how 5 lugs should be mod’d
    cruiserguy and Flippy02[OP] like this.
  4. Dec 28, 2022 at 8:57 PM
    S.Beaty
    S.Beaty Member
    Shawn
    2004 Tacoma ExtraCab 4wd
    Stock
    Great looking truck! What size tires are you running? Fitment looks prefect for the drop.
    Edit: zoomed in 215/70r15 for those also curious.
  5. Dec 28, 2022 at 9:34 PM
    Flippy02
    Central Coast, CA
    Tires are a little bigger than I'd like. I would like to switch to 17x8 rims
