Floating Brake Noise - How to tell
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jspadaro, Oct 29, 2010.
  1. Oct 29, 2010 at 8:03 AM
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I just want to verify the noise I'm hearing isn't just my floating brakes.
    If I back up in a turn, I should not hear the "floating brake" noise until I apply brakes, right?
    The noise I hear is heard without engaging the brakes. The floating brake noise will only happen when I hit the brakes, rigtht? :confused:
  2. Oct 29, 2010 at 8:13 AM
    ec8
    ec8 Newby
    Stuart
    The floating brake noise I hear is when I back out of the driveway and apply the brakes prior to putting into drive, it's only at the point of brake application. I then hear it a second time the very first time I apply my brakes going forward. That's what I always thought of the floating brake noise, but may be different?
    Do you hear the same noise if not turning as you hear turning? Assuming you hear no noise going forward slowly and turning? Leading to a chattering rear diff type of issue.
  3. Oct 29, 2010 at 8:15 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Nah, the noise is only when turning and it happens whether I apply the brake or not. Alright then, that isn't it. (Damn....)
  4. Oct 29, 2010 at 8:41 AM
    ec8
    ec8 Newby
    Stuart
    So if only when turning, do you hear it going forward turning at lower speeds as well or only reverse? I think the rear diff would chatter forward or back. How many miles? rear diff fluid replaced at any time? just started doing this?
  5. Oct 29, 2010 at 11:29 AM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Ended up taking it in because it got past my shade tree skills and also sounded way worse today.
    Apparently a "piece of the suspension" was "bent" and knocking against the frame when the steering was in certain positions. The guy who called me said I could talk to the tech, because he didn't remember what part it was. I'm just hoping it's all fixed now :D
