floating gears
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Jun 11, 2010.
  1. Jun 11, 2010 at 4:41 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    anyone know how to do it, like the right rpms and such to actually not screw anything up?
  2. Jun 11, 2010 at 9:37 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Are you taking about shifting without using the clutch? Find the right RPMs so the gears mesh correctly? It was a lot easier to do before the days of sychromesh transmissions......
  3. Jun 12, 2010 at 3:34 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Need more information....you need to explain a bit more.
    I had a 96 tacoma w/ manual transmission and I never had any problems with shifting.
  4. Jun 12, 2010 at 12:17 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    yeah i was talking about shifting without the clutch, i was just wondering if anyone does it or knows the best way to do it
  5. Jun 12, 2010 at 1:14 PM
    Janster
    Jandy
    Lancaster, PA
    Why would you want to shift without the clutch? You've gotta match the gears/rpm's almost perfectly and hope it slides right in or else you could chew up some gears and god knows what else.
    The best way to do it? USE THE CLUTCH
