Flood Victim Toyota
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PRNYTacToy, Jan 25, 2019.
  1. Jan 25, 2019 at 5:31 AM
    PRNYTacToy
    PRNYTacToy [OP] New Member
    2018 Tacoma TRD 4 door
    I think I started this on another thread less specific to my issue, and so if this is repetitive I'm sorry. I bought a 2018 Tacoma that had been in a flood. Stupid, I know. But a gamble.
    Sometimes I get dash lights like a normal start, sometimes nothing. If I connect the battery and try to start it either way the alarm comes on and prevents anything from happening... although, it will crank over. Windows work, fan works, radio and nav don't. They flash along with the alarm. Door key will unlock the driver's door when inserted but will not work with the remote buttons. I know I'll eventually have to bring it to the dealer, but I want to head off the guessing game, if anyone has any experience like this. The car was pretty deeply flooded in fresh water. It is clean, now and is a brand new car from a dealer who lost about 30 of these things. I'm sure hoping someone has a similar story and a solution. Thanks, all. Robbie
  2. Jan 25, 2019 at 5:34 AM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Man that’s rough, there’s 1,000 things that could be wrong after water intrusion. I’d start by checking all the fuses and relays, grounds and any electrical connections. Did it come with a spare key?
    shane100700 likes this.
  3. Jan 25, 2019 at 5:47 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Good luck, hope you didnt pay too much. Hope they replaced all the ECUs and didnt just try to dry out the old ones
  4. Jan 25, 2019 at 6:01 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Dude, you need to understand how water affects circuit boards and electrical connection points. Any circuit board that was submerged is likely going to need to be replaced - and there could be many. Galvanic corrosion is the problem - look it up and get educated. It gets worse with time. This is why most flood vehicles are write offs.
  5. Jan 25, 2019 at 6:08 AM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I would first completely disconnect the alarm and go from there. Sometimes the if the alarms are screwed up they can do wild things.
    Start one thing at a time and I’d start with alarm first. Then check all fuses etc
    So the truck has not been running at all since you’ve had it correct?
  6. Jan 25, 2019 at 6:11 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    He's right you know. You will get one gremlin fixed today and find two more tomorrow. Chances are it will never stop giving problems. Not unless you replace every single board, harness, fuse, switch, and relay on the vehicle. I'm sorry, friend. If I were in your shoes I'd find a way to get rid of the truck now without taking a devastating loss on it.
    shane100700 and evoix4me like this.
  7. Jan 25, 2019 at 6:19 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    If you could get a list of the items they replaced that would be a big help to you. Whenever we have had to restore a new "totaled" vehicle, the one thing we did/do was to replace all the ECM(s) modules.
    Some things such as carpets & seats can be saved, others like under-carpet laymen and electronics can't.
    Additionally, all electrical connectors that were under need to be disconnected, sprayed & dried. It takes some work, but it can be saved without gremlins in most cases.
    Best of luck
    Cheers
  8. Jan 25, 2019 at 6:33 AM
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    Buy another one that was in a wreck and start swapping out components. The dealers labor rate will quickly eat up any of the savings you had buying it.
    The hammer likes this.
  9. Jan 25, 2019 at 7:02 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Buying a flood vehicle is NOT a gamble...it's almost guaranteed to give you problems.
    You will learn a very expensive lesson from this.
    DES2009 and Garyji like this.
  10. Jan 25, 2019 at 7:17 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    I hope you got it for around 100 bucks. Otherwise you're screwed.
    G.
  11. Jan 25, 2019 at 7:22 AM
    The hammer
    It's a process, it can be done with no issues, but the learning curve can kill you.
    You just need to know how to go about it so it don't bite you
  12. Jan 25, 2019 at 7:25 AM
    Zarot101
    Zarot101 Well-Known Member
    Zachary
    2018 DRK GRY TRD OFF-RD WIP
    Hey, good luck man. I appreciate the effort your taking to learn something new by taking a gamble. Would love to see your progress and read about the different things you learn along the way.
  13. Jan 25, 2019 at 7:40 AM
    evoix4me
    evoix4me Well-Known Member
    Your lucky that’s all the problems you have like others mentioned it’s a money pit and won’t be long before the next issue comes up sell it or trade it in
  14. Jan 25, 2019 at 7:47 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    God bless your dertermination and attempt to salvage a flooded vehicle. Would’ve best been used as a parted out vehicle for body panels rather then something that sees the pavement. Wish you the best with it.
  15. Jan 25, 2019 at 3:40 PM
    Swampdog2019
    Swampdog2019 Active Member
    North Fla
    2019 TRD OR 4X4 DC
    Better call a marine mechanic when you want to rebuild the motor; make it waterproof while you are at it... wish you luck.
  16. Jan 25, 2019 at 3:53 PM
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Let's see some pics! What did you pay?
