Flooded Engine, need help please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cavilry, Sep 6, 2011.
  1. Sep 6, 2011 at 10:58 AM
    cavilry
    cavilry [OP] Well-Known Member
    San Jose, CA
    06 Tacoma TRD 4x4 LT
    Total Chaos Long Travel Kit, King Shocks, Deaver Leafs
    So, lets get it out of the way that I am an idiot apparently. I went through a moderately small water hole without taking into account the fact that the previous owner put in an K&N Performance STREET intake. The one that routes to the fender well and has no real protection.
    As you would imagine, I got a lot of water into the intake. The truck shut down the second I made it to the other side (maybe a 15 foot wide hole). I heard no loud noises or anything, it just shut off without much commotion. When I tried to start it (dumb, I know) I just heard a click, nothing too loud. After inspecting the situation, we realized what happened (water pouring out of the intake). We got towed off the trail about 100 yards to the road where we proceeded to do surgery.
    We removed the intake, manifold, plenum, coils, and plugs. After getting it all off, we took a turkey baster with some straws taped to them and sucked out about 10-15 oz. of water. I went to turn it over to get any other water out if possible but no go. The same thing of not starting. It would just click, like it wanted to turn over but couldn't. I tried to get a wrench on the engine to turn it over but could not get much leverage.
    Any ideas? I am thinking maybe the starter or solenoid? I guess I should say "I am HOPING maybe the starter or solenoid?" More and more I am getting the sinking feeling that it is a bent rod or something along those lines. Unfortunately, I had to get back to town for work (and for my friend's work) so the truck is now 320 miles away until the weekend. Frick...
  2. Sep 6, 2011 at 11:00 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Starter is more than likely toast. I would bet the alternator is FUBAR also.
  3. Sep 6, 2011 at 11:03 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    You didn't re-install the plugs before trying to turn the engine over again, did you?
    How high were you revving when the engine stopped?
  4. Sep 6, 2011 at 11:05 AM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Damn this is a bad story OP. I would start at the starter and its good then you have worse probs. Not sure but maybe they have some kind of shutoff in the ecu, maybe someone else might know. If so I would disconnect the battery and see what it does. I highly doubt you did internal damage to the engine though, not from some water in the cyclinders. Good luck.
  5. Sep 6, 2011 at 11:08 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    You sir have hydrolocked your motor. The "click" you are hearing is the starter trying to turn the motor over. However, it won't move because you either
    1) Bent a connecting rod or two (commonly referred to as "s-ing" the rods). Instead of the rods being strait, they are now in the shape of an S
    2) Broke a connecting rod or two (same as above, but with babies in the oil pan)
    Pull the spark plugs and drain the oil. If the oil comes out milkey, you're fucked. Then put a 19mm socket on the crank pulley and try to rotate it clockwise. If it doesn't rotate....you're again fucked.
    Ask me how I know
    http://www.tacomaworld.com/forum/1s...ion-resurrection-redemption-tacoma-story.html
  6. Sep 6, 2011 at 11:10 AM
    SampleFool
    Ga
    Silver
    08 off-road
    Wow that sucks.
  7. Sep 6, 2011 at 11:17 AM
    cavilry
    San Jose, CA
    Thanks for the quick feedback all, y'all never cease to amaze me. It was a pretty horrible experience but I got to spend some more time in my old stomping grounds with some great friends...lifes little adventures eh?
    I would say that I was probably under 3K RPM when I went in, but I can't say for sure. I am sure I at least tried to punch it when I was in the water, whether or not it had started to die by then, who knows.
    The plugs were out when I tried to restart it the last two times (did it twice right outta the water before taking everything apart and getting the water out).
    I definitely hydrolocked the engine. I guess I did not know if it was always going to definitely end up being an issue of bent rods or if there was any hope.
    I have a mobile mechanic friend up there, so I will let him know what to look for when he gets a chance to check it out today or tomorrow.
    Anyone got a spare engine for sale??? :-/
  8. Sep 6, 2011 at 11:21 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
  9. Sep 6, 2011 at 11:24 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Keep us posted.
  10. Sep 6, 2011 at 11:27 AM
    cavilry
    San Jose, CA
    Thanks so much. Fingers crossed that it won't be needed but looks like a good source...Anyone know if AAA covers water crossings on dirt roads???? :rolleyes:
  11. Sep 6, 2011 at 11:30 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes I do know. I have AAA. :D
    Give them the name of the road (even if its a nickname). My truck was hydrolocked on "Sand Highway" near Pier ave in Oceano, CA.
    I was honest and open about what happened and it was covered under comprehensive. $100 deductable.
  12. Sep 6, 2011 at 11:32 AM
    MartyMcfly
    MartyMcfly Time Traveler
    ROB
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    My insurance company covered mine under the comprehensive coverage for "flood damage"
    Good luck.
  13. Sep 6, 2011 at 11:32 AM
    cavilry
    San Jose, CA
  14. Sep 6, 2011 at 11:33 AM
    colder
    colder Well-Known Member
    MN
    2011 Access Cab TRD Sport
  15. Sep 6, 2011 at 11:38 AM
    MartyMcfly
    ROB
    Pahrump Nevada
  16. Sep 6, 2011 at 11:46 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Replace Lincoln road with Sand Highway and that was...to the letter...my story to AAA. :rolleyes:
  17. Sep 7, 2011 at 12:23 PM
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Great time for a Diesel mod. Sorry, that sux![​IMG]
  18. Sep 7, 2011 at 1:43 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    No diesel swaps in CA (not legally anyway)
  19. Sep 7, 2011 at 2:00 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Anything is legal as long as the referee who's looking at it says ok. ;)
  20. Sep 7, 2011 at 2:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
