Flooded motor
Discussion in 'Technical Chat' started by BAMFTACO, Mar 25, 2012.
  1. Mar 25, 2012 at 3:17 PM
    BAMFTACO
    BAMFTACO [OP] Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    So I just went through this deep puddle and got water in my intake/motor and I drove it to my local napa and got new air filter and it was running rough now it's better. I checked the oil not milky but I'm still puting new oil what else should I do and look out for.
    Thanks for any help.
  2. Mar 25, 2012 at 3:20 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
  3. Mar 25, 2012 at 3:24 PM
    BAMFTACO
    Juan
    Kings bruh
    I Didnt think it was that deep and went through it and my truck stalled out immediately luckily it didn't stall in the puddle it barely got out
  4. Mar 25, 2012 at 3:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Oil change is about all you can do.
    Running rough could just be wet connectors or electronics, particularly the high voltage system.
    Should be running better when it dries out Wednesday.
  5. Mar 25, 2012 at 3:30 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Did you do the rear differential breather mod? If not you might want to change out the fluid depending on how deep the puddle was.
  6. Mar 25, 2012 at 3:31 PM
    BAMFTACO
    Juan
    Kings bruh
    Water got into the cylinder for sure and water is out so I'll update on what happens tomorrow I'm gunna do my oil change and then later on do my plugs I need to do them any ways . But any other advice would be much appreciated.
  7. Mar 25, 2012 at 3:33 PM
    BAMFTACO
    Juan
    Kings bruh
    I went through the puddle fast and do you think water still got in it
  8. Mar 25, 2012 at 3:44 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    clean ur MAF sensor .....
  9. Mar 25, 2012 at 3:46 PM
    BAMFTACO
    Juan
    Kings bruh
    Totally for got about that thanks
  10. Mar 25, 2012 at 3:50 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Why risk a diff?
    But probably not if you went through it quickly
  11. Mar 26, 2012 at 1:34 PM
    BAMFTACO
    Juan
    Kings bruh
    Okay so this morning engine light went on and then today I change the oil and oil filter and the change the air filter/ cleaned my mass air flow sensor. Then my friend has a good ob2 computer and we hooked it up and now my o2 sensors arent reading I guess there either plugged up or the water fucked them up. How much do o2 sensors go for?
  12. Mar 26, 2012 at 1:46 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    iirc ~100 each
  13. Mar 26, 2012 at 1:49 PM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    keep us updated, sorry to hear that man.
  14. Mar 26, 2012 at 3:35 PM
    BAMFTACO
    Juan
    Kings bruh
    100 bucks each dam and yeah I'll keep updated is there any way to take them out a clean it
  15. Apr 11, 2012 at 8:15 PM
    BAMFTACO
    Juan
    Kings bruh
    So I finally got some free time and ended up buying a obd2 scanner and I plugged it in to my truck and it said bank 2 sensor 1 is not getting enough voltage and was wondering if any one had any in put on this any help would be nice
  16. Apr 11, 2012 at 8:42 PM
    BAMFTACO
    Juan
    Kings bruh
    It's sucks tomorrow I'm gunna see if theres any connectors loose but was wondering if anyone had any insight on we're to start the scanner says its not getting voltage so my guess something got loose or maybe a relay got screwed
  17. Apr 11, 2012 at 8:54 PM
    SAS T4R
    SAS T4R That baby don't look like me
    NM
    06 Double Cab TRD Off-Road 4x4
    You should try adding a quart of ATF to the motor oil and let it idle for about 10 minutes. ATF has a lot of detergents and breaks down water well. Do that, then change your oil and filter again. Remember, water doesn't compress very well in an engine lol. You're lucky that you didn't hydro-lock the engine.
  18. Apr 11, 2012 at 8:54 PM
    SAS T4R
    NM
    Oh, and your O2 sensors are probably shot as well.
  19. Apr 11, 2012 at 8:58 PM
    BAMFTACO
    Juan
    Kings bruh
    Tell me about it it's be couple weeks I've been checking the oil and everything. Haven't got any random pinging or knocks from the motor and now the only really damage is those sensors.
  20. Apr 11, 2012 at 9:03 PM
    SAS T4R
    NM
    Good luck man, I hope it turns out well. I'm sure you'll rethink the puddle next time lol
