Floor Jack for 3" lifted Tacomas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ItalynStylion, May 3, 2016.
  1. May 3, 2016 at 8:32 PM
    #41
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    Should be, as long as you don't try to center the jack and lift the entire vehicle. ;)
  2. May 3, 2016 at 9:33 PM
    #42
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I got my Costco Arcan 2.5 ton jack for $60. Can't complain. That's where the 4x4 block of wood comes in handy for extra lift.
  3. May 4, 2016 at 6:48 AM
    #43
    ItalynStylion
    ItalynStylion [OP] Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I think, at least for me, the Arcan won't work. I would love having the extra bit of lift but at nearly double the weight it's just not feasable. The jack will serve double duty for me and will likely be put into the car at some point or another for days at the race track (changing to track wheels/tires). I can't imagine lugging the 100lb Arcan around.
  4. May 4, 2016 at 6:55 AM
    #44
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Something I'd recommend is picking up some hydraulic jack oil. Some people complained about the HF jack not holding anything up after a few months. The day I bought mine, I topped of the oil (it needed a bunch) and then bled the system. Took all of 5 minutes and the jack works flawlessly.
    Biscuits likes this.
  5. May 4, 2016 at 7:03 AM
    #45
    K.Ray
    K.Ray Well-Known Member
    East TN
    2016 Toyota Tacoma TRD Off-Road, 6sp Manual, Quicksand
    None
    It is really 100lbs but that helps keep things strong and sturdy. I've had zero issues with the weight and don't notice it at all compared to my other jacks.
    I highly recommend going with the XL35 flavor, as it's cheaper. You lose a few inches but gain the extra lift capacity. You can grab the XL35 specific Arcan model in store at Northern Tools and stack a coupon to get it even cheaper than $189. The XL2T is online only. That same model is also used by Costco and a few others.
  6. May 4, 2016 at 10:41 AM
    #46
    ItalynStylion
    Steven
    DFW, Tx.
    Good to know. Cheaper, holds more weight, and lifts about 21.5"....that's compelling. Still super freaking heavy though. Does Northern Tool have coupons often?
  7. May 4, 2016 at 11:11 AM
    #47
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Thats the same one I got from costco. I love that thing.
    Arcan XL-35R
    3.5 Ton - Low Profile
    23 inch lift height
    $99 at costco years ago.
    14489[QUOTED] likes this.
  8. May 4, 2016 at 12:10 PM
    #48
    K.Ray
    East TN
    None
    They do - http://www.retailmenot.com/view/northerntool.com or just google for some. They use a six digit code, I believe. The cashier will just take it from you off your phone. They don't discriminate.
    I bought mine on sale so total was $120, I believe, after coupon.
  9. May 4, 2016 at 12:15 PM
    #49
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    Eagle off-road jack I love mine
  10. May 4, 2016 at 12:25 PM
    #50
    Soflanick
    Soflanick Well-Known Member
    Nick
    FLORIDA
    2001 tacoma prerunner
    5100 front, 5125 rear, 2"all, old ARE topper, 16x8 XD enduro's on 265/75r16 KO2's
    That's the one I use, low profile. Works amazing.
    Just pick a jack and use a 4x4 to add the extra lift you need. Having a lifted truck you kinda screw yourself. My .02
  11. May 4, 2016 at 1:12 PM
    #51
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
  12. May 4, 2016 at 2:00 PM
    #52
    Drtgrl
    Drtgrl Minus member
    Alana
    Foothills
    2015 MGM Tacoma DCLB
    BAMF sliders with kick up. BAMF all skids. Icons w/ CDC up front. Icon UCA's. All pro expos with 12” kings in rear. Wheelers superbumps. 285 stt pros on black 16" fj wheels. 1" Bora wheel spacers. Relentless tailgate reinforcement. Ditch lights front and rear. Aironboard switches. Aux. bussman box.Center console vault. Esp locking storage. Tuffy bed box. Rear seat molle system. Color matched grill.Rear diff breather mod. ABS switch. PrInSu cab rack. Gusseted spindles.
    Harbor Freight one might not be enough. I have HF steel one with the same lift height and I still need to use a block to get the tire off the ground
  13. May 9, 2016 at 7:04 AM
    #53
    ItalynStylion
    Steven
    DFW, Tx.
    Just to give people some closure....I ended up with the Jegs aluminum jack. Light, good lifting height, and 3 ton lifting capacity were enough to get me to pull the trigger. I plan on following up once I've got some time under the truck with the new jack (which should be soon).
    Crom likes this.
  14. Jun 2, 2016 at 11:44 AM
    #54
    wadeo
    wadeo Well-Known Member
    Harrisburg, PA
    2018 TRD OR DCSB 4x4 BBP
  15. Jun 2, 2016 at 12:04 PM
    #55
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    A good read on jack stands by the way from our fellow Toyota Land Cruiser brothers: http://forum.ih8mud.com/threads/the-bitch-tried-to-kill-me.305105/ http://forum.ih8mud.com/threads/harbor-freight-jack-stands-safety-warning.307482/ After reading those I went with the Torin 6-Ton Stands with the locks. Overkill for my FJ40, but they were great on the FJ60/Tacoma.
    As for the Jack, I went with the Costco Arcan as well. It has been very solid for lifting rigs over the years. The trick on the Tacoma's I found was using the front cross member (on my 1999 at least) and the rear axle on the backside.
    Biscuits and rob1208 like this.
  16. Jun 2, 2016 at 12:05 PM
    #56
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    I bet that Jegs jack comes out of the same factory as the Harbor Freight.
  17. Jun 2, 2016 at 12:24 PM
    #57
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Seems like Costco stopped carrying the Arcan, as I've only seen the aluminum low-profile jack in the store lately. My Arcan has been great for years.
    I don't doubt it. I wouldn't buy anything with more than 5 moving parts or a motor there, but Harbor Freight is a great place for high-lift jack stands.
    PS - in case it hasn't been said enough ... never crawl under your truck unless it's on jack stands! My dad lost a good friend who was betrayed by his trusty jack during a "quick" repair.
  18. Jun 2, 2016 at 12:39 PM
    #58
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Unfortunately they did discontinue the XL35R / XL325R and now only offer that hybrid steel/alum. one. Glad I got mine when I could. :D
  19. Jun 2, 2016 at 1:59 PM
    #59
    ItalynStylion
    Steven
    DFW, Tx.
    As stated earlier, I ended up with the Jegs jack.
    Very happy with it thus far. Good lift capability and it gets much higher than my old one. For such a beefy jack it is actually pretty light. Lifts the truck like it's nothing. I've already used it 3 different times (LCA cam bolts, rear leaf bushings, adjusting coils) and I'm still loving it.
