Floor Jack for truck lifted 3" - Jack Height??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hairy Taco, Oct 6, 2012.
  1. Oct 6, 2012 at 11:48 AM
    Hairy Taco
    Hairy Taco [OP] Jungle of Love
    North of Hell
    08 TRD
    I am looking at purchasing a floor jack. My truck has a 3" lift. What height floor jack is typically required to get the tires off of the ground?
  2. Oct 6, 2012 at 11:53 AM
    RyanK1
    RyanK1 Well-Known Member
    Penticton, British Columbia
    2006 Tacoma TRD Sport
    Bilstein 5100's @ 2.5, TSB rear with block spacer, Procomp ES9000's, CBI Moab 2.0 front bumper, swaybar removed, DIY HiLift mount, Rear diff breather mod, ABS Kill Switch, Flowmaster 40 series muffler, Superwinch 8500
    I had a hard time with my smaller floor jack, I ended up using my hi-lift off the front bumper.
  3. Oct 6, 2012 at 11:54 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Get a HF floor jack with the highest reach. Use a 4x4 block if you need to.
  4. Oct 6, 2012 at 11:55 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Hi-lift, FTW. Also went to the local auto store and bought the tallest floor jack they had. If it's not enough, I guess you could put a 4x4 block on top? :notsure:
  5. Oct 6, 2012 at 12:00 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    IIRC, there are accessories available for the hi-lifts to use on vehicles without armor.
  6. Oct 6, 2012 at 12:00 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Pretty much.
  7. Oct 6, 2012 at 12:06 PM
    Hairy Taco
    North of Hell
    08 TRD
    The readily available floor jacks lift to either 14", 19" or 21" it seems. I just wonder if these lift high enough to pull off the wheels.
    No Sliders.
  8. Oct 6, 2012 at 12:18 PM
    Hairy Taco
    North of Hell
    08 TRD
    Ok, so it looks like you have your Billys at 1.75. Do you recall whether you are maxing out your jack when you use it?
  9. Oct 6, 2012 at 12:23 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
  10. Oct 6, 2012 at 12:28 PM
    Hairy Taco
    North of Hell
    08 TRD
    ok cool, thanks. I found the jack on Arcan's site. Looks like it lifts 21.3" . Sounds like it should be enough then.
    http://arcanusa.com/lifting.html
  11. Oct 6, 2012 at 12:30 PM
    Hairy Taco
    North of Hell
    08 TRD
  12. Oct 6, 2012 at 12:31 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    That jack looks so sketchy.
    Try using a high lift with LT! It's difficult.....
    I find a regular floor jack works for me with 35s. Definitely get a stronger beefier one. Generally those are also a little taller.
  13. Oct 6, 2012 at 12:33 PM
    Hairy Taco
    North of Hell
    08 TRD
    They have a lot of choices. Thanks for the link.
  14. Oct 6, 2012 at 12:35 PM
    Hairy Taco
    North of Hell
    08 TRD
    A scissor or bottle style jack? I am also thinking about just getting a biggor scissor jack.
  15. Oct 6, 2012 at 12:44 PM
    Hairy Taco
    North of Hell
    08 TRD
    Normally I use the recommended points. The side frame on the front and the axle on the back I believe.
  16. Oct 6, 2012 at 12:49 PM
    Hairy Taco
    North of Hell
    08 TRD
    thanks for all of the input guys. It is appreciated.
  17. Oct 6, 2012 at 6:51 PM
    Hairy Taco
    North of Hell
    08 TRD
    Anyone out there using a floor jack under their 3" lift? If so how many inches does your jack lift?
  18. Oct 7, 2012 at 6:22 PM
    Spoonman
    Jamie
    Alberta
    I don't like bottle jacks, they're very unstable. And if you're trying to use it on the trail? Forget about it. I use this type at home, but it's not a bad idea to bring it on the trail. Sometimes a hi-lift doesn't get the job done.
  19. Oct 7, 2012 at 7:36 PM
    Hairy Taco
    North of Hell
    08 TRD
    what height does yours lift to? I want to pick one up. I am looking at some that lift 15", some that lift 19" and some that lift 21" . I just want to be sure the one I get lifts high enough. I really dont wanna have to block it up higher.
    Anyone? thanks
  20. Jan 20, 2013 at 12:49 PM
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Im wondering the same thing, I wanna buy a floor jack and am not sure how high it needs to be.
