Floor Jack Recommendations
Discussion in 'Garage / Workshop' started by MoQS, Mar 21, 2011.
  1. Mar 21, 2011 at 5:16 PM
    MoQS
    MoQS [OP] Well-Known Member
    Merel
    Missouri
    MGM OR DCSB
    I have been looking to buy a decent floor Jack.
    This is the one that is most appealing to me.
    From Harbor Freight. It has mixed reviews on their site.
    Raises to an 18-1/4" maximum height in just 6 strokes!
    • Low-profile saddle with 3-1/4" minimum height rotates 360®, non-marring rubber cap
    • Load releases by a simple half-turn of the two-piece knurled aluminum handle
    • Precision-machined, high-strength aircraft aluminum billet weighs just 45 lbs.
    • Two easy-lifting side handles
    • Four aluminum wheels (two fixed in front, two swivel in rear)
    Lifting range: 3-1/4" to 18-1/4" Saddle pad dimensions: 3-5/8"L x 3-5/8"W x 1/4"T Overall dimensions: 27-1/2" L x 12" W Shipping Weight: 49.05 lbs.
    Does anyone own this floor jack?
    Any comments about this jack or suggestions for something else?
    I need something relatively light as I do have some back issues.
  2. Mar 21, 2011 at 6:21 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    I have it and it is very light and works pretty well. Takes more than 6 pumps but still lifts fast. havent had any problems with it yet, only had it for a year. Have other jacks but use this one because it is so nice how light it is.
  3. Mar 21, 2011 at 6:31 PM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    I heard that about Craftsman.
    atvlifestyle: is the jack tall enough get get your Taco off of the ground?
  4. Mar 21, 2011 at 6:35 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I have a good aluminum floor jack (can't remember rating) that is heavy duty and bought it at COSTCO ... maybe 5 to 7 years ago.
  5. Mar 21, 2011 at 6:40 PM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    :popcorn:I need to buy a jack too.
  6. Mar 21, 2011 at 6:43 PM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    I looked at Costco and on their web site but had no luck
  7. Mar 22, 2011 at 10:10 AM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
    Bumping for more recommendations.
  8. Mar 22, 2011 at 12:56 PM
    sdnicker2000
    sdnicker2000 Well-Known Member
    Nebraska
    Mostly Stock 08 TRD Sport
    Rear spring TSB, Fumoto Valve, No A/C on defrost mod., tailgate theft mod.
    Napa 3 1/2 Ton. A little pricey but worth it in my mind.
  9. Mar 22, 2011 at 1:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    All the jacks are manufactured inexpensively now.
    I recommend buying from a local auto parts store, and saving your receipt, so that if there's a problem, you can return it easily.
    I bought the AC/Delco from my local O'Reilly(nee Kragen)
  10. Mar 22, 2011 at 1:22 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I bought a cheap floor jack from the local auto parts store 25 years, and the cheap SOB just failed...
    Personally, get the heaviest, longest frame jack you can find. You don't need more than 2 metric ton capacity for your taco, but flexibility in nice. Remember, this is GARAGE equipment, not mobil equipment.
    Howard
  11. Mar 22, 2011 at 6:23 PM
    atvlifestyle
    Michigan
    01 trd tacoma
    the harbor freight jack lifts just as high as any other. Which means it wont lift the rear wheels all the way off the ground when on the frame.
    I have two craftsman jacks that have different problems, one blew the seal after about a year. They both cost more than the Harbor Freight one.
  12. Mar 22, 2011 at 11:02 PM
    MoQS
    Merel
    Missouri
    MGM OR DCSB
  13. Mar 23, 2011 at 10:26 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    I bought the Harbor Freight one when it was on sale for pretty cheap, not bad. I had a Napa low-rider jack (got under lowered cars easy) for about 8 years til I got to SD, then some bum jacked it out of my garage....oh the irony.
    I'll probably buy another Napa jack when I have a better garage situation cause carrying it would be a PITA.
