Floor Jack Saddle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by C_Mac, Jul 16, 2023.
  1. Jul 16, 2023 at 12:06 PM
    C_Mac
    C_Mac [OP] New Member
    2012 Tacoma TRD Sport
    So I decided I wanted to try to do some maintenance on my truck myself, and bought a 3t Big Red floor jack. I now realize that the saddle is very small and does not fit around the center front jacking point. I'm concerned it might slip off. Does anyone have any recommendations or am I worrying for nothing?
    Here is a link to the jack:
    https://www.amazon.ca/Torin-Hydraulic-Trolley-Floor-Jack/dp/B0028JW4PU?th=1
    Thanks!
  2. Jul 16, 2023 at 12:16 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I would return it and get a something larger.
    I don’t know, but it seems awfully small to me.
    A lot of us use blocks of wood to increase surface area or for a better reach.
    Something like this.
    C_Mac[OP], usmc2msu and goforbroke123 like this.
  3. Jul 16, 2023 at 12:21 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    C_Mac[OP] likes this.
  4. Jul 16, 2023 at 12:30 PM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    x2
    Get a legit jack.
    I actually have that little red jack, it’s a joke. For a car it’s fine, but not for a truck. My buddy gave it to me after I let him borrow my big aluminum HF Jack that was in his car one night. The magical night his car got stolen.
    C_Mac[OP] and GilbertOz like this.
  5. Jul 16, 2023 at 12:45 PM
    C_Mac
    Thanks for the replies. I think I'm past the point to return it, so I guess I'd need to sell it. I was thinking maybe I could try a hockey puck or wood block first, but I'd still be worried it would slip.
  6. Jul 16, 2023 at 12:51 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    You may be able to put a different cup on it. The front never seems to jack up level. If you need height I would find something solid to put under jack!
    Always use jack stands tires blocks something so your wife or neighbor doesn’t find you crushed under the vehicle!
  7. Jul 16, 2023 at 1:00 PM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    C_Mac[OP] and Jeffch like this.
  8. Jul 16, 2023 at 1:04 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    I bought something like this for mine because newer cars have limited jack points.
    Using the pinch weld part without one will crush pinch weld. I had to Machine it so it fit my jack.
  9. Jul 16, 2023 at 1:22 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
  10. Jul 16, 2023 at 1:27 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Just jack a corner at a time (if possible for the project you are doing) and jack against a flat part of the frame.
    po35042 and C_Mac[OP] like this.
  11. Jul 16, 2023 at 1:59 PM
    C_Mac
    Thanks all for your input. I'll try to return it and get something better. The reason I went with that jack was because of the height, since my truck has a 3 inch lift.
  12. Jul 16, 2023 at 2:38 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    It never hurts to have an extra jack for mobile uses, so keep the small one for just in case.
    I finally bought one of these for home garage work and really like it: It gets taller than any floor jack they sell and will still fit under a sports car when down. Make sure you look for the words LONG REACH on the box.
    And above all, invest in a good set of jack stands if you haven't already. Don't get under there with the jack alone.
    These are plenty tall and beefy for a lifted tacoma, I've been happy with them:
    https://www.amazon.com/Pro-LifT-T-6...3412&sprefix=6+ton+jack+stands,aps,178&sr=8-6
  13. Jul 16, 2023 at 3:02 PM
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Always remember something needs to move either the vehicle or the jack!
    I got rid of my old floor jack rip cause it was leaking and wheels froze from rust!
