Floor jack
Discussion in 'Garage / Workshop' started by Glocker23, Mar 31, 2015.
  1. Apr 11, 2015 at 6:06 PM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    I just bought a Ranger Quickjack. Jack and stands all in one.
  2. Apr 11, 2015 at 6:17 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Under the engine, there is a bump down in the center of the crossmember, behind the skidplate... that is always a good lift point for raising the entire front end.
  3. May 16, 2015 at 4:40 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have been buying all my Jacks from the local Hydraulic Repair vendor . The good thing is they service what they sell .
    I have 3 floating around now
    Not sure how many sets of jack stands
  4. May 16, 2015 at 4:47 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    I bought a Big Red Jacks "truck and SUV" 3 ton jack from pep boys a couple months ago. It was 70 bucks and has enough lift to lift my tires off the ground (even with 3" lift and 33"s) and hasn't had any problems yet.
  5. May 16, 2015 at 9:51 PM
    D50boy
    D50boy Well-Known Member
    Kenneth
    Texas
    I'm using a Harbor Freight 3ton. You can usually find a coupon hanging out in the back of magazines. Definitely worth the money.
  6. May 17, 2015 at 3:22 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Same here, got the low profile. No complaiints so far.
    Rusty1606 likes this.
  7. May 18, 2015 at 6:13 AM
    Glocker23
    Glocker23 [OP] Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    OK cool. So far HF has those for 199.
  8. Jun 12, 2015 at 9:41 AM
    Indy
    Indy Master of all I survey.
    It depends. How high is your lift?
    I've gone through a dozen "2 ton" floor jacks over the years. They all seem to leak, once or twice they would leak pressure faster than I could jack. I bought a HF 3 ton floor jack, so far it's worked very well. Except the bolt holding the handle in place keeps working loose.
  9. Jun 12, 2015 at 9:47 AM
    ricantaco
    ricantaco Well-Known Member
    Thanh
    Bay Area, CA
    2015 DBC TRD OR
    Between Harbor Freight and Craftsman, go with the HF Jack. I have 2 Craftsman Jacks that failed. Though replaced under warranty, it is a PITA
  10. Jun 12, 2015 at 9:47 AM
    ricantaco
    Thanh
    Bay Area, CA
    2015 DBC TRD OR
    I did get an Arcan Steel Hydraulic Jack years ago at Costco. They no longer sell those there but its been the best. I have two and both are in perfect working condition.
  11. Jun 12, 2015 at 9:55 AM
    Glocker23
    CT
    2012 DCSB Sport
    Scooped up a HF 3 ton jack. Sadly it was the heavy one not the race version. But it was also on sale $75 bucks off. Got it for 89. Had to grab it. With 2 6ton jacks. Thanks for the help fellas
  12. Jun 15, 2015 at 9:50 AM
    foampile
    foampile Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
  13. Jun 21, 2015 at 12:55 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    No experience with the HF jacks, but I might look into them now. The Craftsman aluminum at work leaks oil like a sieve and is only 5 years old. Currently have a 3 ton Kobalt steel that works great, but is getting harder to move around the shop with my uncooperative lower back.
  14. Jun 21, 2015 at 1:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I own a Craftsman Floor jack. We've had it for probably 15 years .....and it's been perfect. They probably don't make them like that anymore..... a damn shame.
    I also own a Harbor Freight alluminum / blue racing (??) jack. This is our 2nd one. The first one failed the first time we used it. Popped a seal or something. Took it back and we currently have the replacement. I don't trust it..... I never use that one for anything that's critical. It's more for 'support'.
    Harbor Freight Jackstands are awesome..... Just be very careful with their hydraulic jacks.
  15. Jun 24, 2015 at 12:30 PM
    #35
    cynicalrider
    cynicalrider #NFG
    Jersey
    I recommend 3 ton jack minimum. Just picked up a 3 ton low pro jack for $94 at HF. The low profile jack lifts an inch and a half higher than the standard 3 ton. The reason I recommend 3 ton is because Fabio's 5000lb truck did this to my craftsman 2.5 ton jack lifting from his pumpkin.
    Also I easily recommend having the 6 ton jack stands for the extra lift height especially with lifted trucks. When doing rear suspensions it's nice running 2 6 ton's to hold the truck up and my smaller craftsman jacks to hold the axle.
    6 tons at work:
    Rear axle example here:
    Tested the low pro jack this weekend and used a 4x6 to boost the height on the jack to lift the front of my truck up by the front xmember. Did it really well.
  16. Jun 24, 2015 at 12:50 PM
    #36
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    I have the HF low pro aluminum jack and made a couple of spacer bocks from 4x4 hardwood 1 3" and 1 6" which allows the low pro to lift a lifted 4x4 and is still light enough to throw in the back and move where I need it. Have had and used several HF bottle jacks with no problems.
  17. Jul 7, 2015 at 9:25 AM
    #37
    Indy
    I think you're taking the 'glass is half empty' view. You now have the perfect jack to use on sloped driveways.
    choupick, Rusty1606 and DrFunker like this.
  18. Jul 7, 2015 at 9:31 AM
    #38
    foampile
    Mid-Atlantic
    do you have experience mounting a tranny adapter on this thing ?
  19. Jul 7, 2015 at 9:35 AM
    #39
    DrFunker
    DrFunker Well-Known Member
    That is funny. :laughing:
  20. Sep 28, 2015 at 7:32 AM
    #40
    Maticuno
    2011 Suburban 2500
