Floor jacks off road
Discussion in 'Recovery' started by desert runner, Nov 26, 2017.
  1. Nov 26, 2017 at 6:59 PM
    desert runner
    desert runner [OP] Member
    Greetings,
    Has anyone had any luck using light weight floor jacks in lieu of a high lift? I’ve had many people tell me to leave the high lift at home.
  2. Nov 26, 2017 at 7:07 PM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    High lifts can be great to jack you off a rock get out a difficult situation i would never use one as the sole lift if i needed to work on my truck on the trail. They are a valuable tool but unless you’ve practiced with it quite some bit in multiple situations I’d leave it at home. They can be very dangerous if used improperly. Honestly if you’re on the trail and legit broke and needed to get under the truck you’re going to want a few forms of assurance when working underneath the truck. I usually put the spare uner the frame right next to me if possible
    DrFunker likes this.
  3. Nov 26, 2017 at 7:53 PM
    desert runner
    Good advice. Maybe a couple of jack stands in the truck would be advisable.
  4. Dec 1, 2017 at 10:23 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Leave the high lift at home?! Nah! Just know how to use it and when.
    As the name implies, however, it should be used to *lift* the vehicle, not support it. So if you need to lift it up to work under it, you sure as shit should pile up some rocks, etc... and not use it as the sole support.
    High lifts can also be used as a winch, so don’t leave it home, just practice with it and know how to use it.
    I wouldn’t bother with bringing jack stands, the likelihood that you’d be able to use them (safely) is pretty much nil while off road, unless you break something on flat level ground. high lifts at least are designed to use on uneven ground, jack stands are not.
    Key-Rei likes this.
  5. Dec 1, 2017 at 10:31 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I don't have a highlift yet, but I do keep a small floor jack in my recovery box, I also keep a plank with me for use with the jack as the few times I've had to use it have been on soft ground and without the board I just jack the jack into the dirt vs the truck off the ground.
  6. Dec 1, 2017 at 10:34 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Pro Eagle
    Has a large flat skid plate on the bottom to keep it from sinking into the ground.
    Taco_Craig and Lord Helmet like this.
  7. Dec 7, 2017 at 4:57 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I wanna take who ever told you to leave the hi lift at home off roading. Make no mistake, it is a RECOVERY TOOL ONLY. It can help with repairs, but it is not a repair tool itself. They don't call them widowmaker jacks for nothing. Knock your head clean off.
  8. Jan 22, 2018 at 9:07 PM
    msegal55
    msegal55 Insta: babe.the.blue.ox
    Mitch
    Orange County CA
    18 Cavalry Blue Trd Pro
    this thing is great
    They always sell out on Amazon. should be only about $38
  9. Feb 17, 2018 at 9:28 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  10. Feb 17, 2018 at 11:53 AM
    beez65
    beez65 Well-Known Member
    Oakland, CA
    2004 Double Cab 4x 3.4 AT
    Bilsteins, ToyTech, AAL, American Racing wheels, stock size tires. FOR NOW! :)
  11. Feb 17, 2018 at 12:19 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    There was another seller... Lemme look
  12. Feb 17, 2018 at 12:24 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  13. Feb 17, 2018 at 12:25 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  14. Feb 17, 2018 at 12:27 PM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
  15. Feb 17, 2018 at 12:28 PM
    msegal55
    Mitch
    Orange County CA
    Add it to your cart on Amazon and keep checking. They will get them in stock and sell for about $38
  16. Feb 17, 2018 at 12:48 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    this is actually pretty genius, no need for a floor jack! Except i would still need to use mine on occasion for articulating the axle
    msegal55[QUOTED] likes this.
  17. Feb 17, 2018 at 12:49 PM
    DrFunker
    DrFunker Well-Known Member
  18. Feb 17, 2018 at 12:56 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Depends on who you ask, floor jack will be fine for most things. Heavy shit I'd start to want something like a high lift. I didn't want to buy a boutique item like the Proeagle and still need my hilift so just opted to just learn to be super safe with the hilift and it has never let me down. I keep a single jack stand with me in my OSK. All the guys I wheel with keep a jackstand as well in case we ever need more than one. Highlift has always been good to us and allows lots of versatility for jacking points on an armored truck.
    Jcyr and DrFunker like this.
  19. Feb 17, 2018 at 2:21 PM
    Harvo
    Harvo Hanging On !!!
    17' TRD Offroad DCSB
    SpiderTrax, RCI Sliders, Warn bumper, Smittybuilt winch, Ridge Grapplers...
    Used to carry a hi lift off roading everywhere. Used it often but realized that in every case a bottle Jack would have worked. The hi lift handle busted my eyebrow once too. Resulted in stitches.
    The hi lift hangs on the wall now. I carry a bottle Jack and a platform for it.
    I've seen people try to use a hi lift as a winch. They ended up using my winch lol. The only other thing I have seen it useful for besides a Jack was a big clamp.
  20. Feb 17, 2018 at 4:56 PM
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    DrFunker[QUOTED] and REDdawn6 like this.
