Floormat Clips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kurtw, May 14, 2020.
  1. May 14, 2020 at 2:41 PM
    kurtw
    kurtw [OP] Extra Regular
    Kurt
    Leander, TX
    07 PreRunner Double Cab TRD Sport - Sold / 2016 4runner Trail Premium
    So I had one of the floor mat retaining clips in my truck break a little while back. It also looks like the carpet kind of warped where the clip connected. Anyone come across a good solution for this?
  2. May 14, 2020 at 3:09 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Go to caliraised I believe they sell a floor mat clip.
  3. May 14, 2020 at 3:12 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    If you ever make your way out to San Diego I have an entire Double Cab carpet you can have.
    kurtw[QUOTED][OP] likes this.
  4. May 14, 2020 at 3:15 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
  5. May 14, 2020 at 3:30 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    That mat retainer clip style looks like the kind I have on my 2003 Gen 1. My 2015 Gen 2 has the toggle-style retainer.
    The dealer will give you a set of those mat clips for free at any Toyota parts counter I've visited. As noted, that carpet is missing a grommet -- ya gotta do something there or it's only going to get worse. I can't recall if the clip kit includes the grommet -- it might.
  6. May 14, 2020 at 6:29 PM
    4xdog
    Santa Fe, NM
    Your hook looks like it's mounted upside-down, BTW. The split post goes in the floor grommet, and the hook piece goes through the mat.
    This is likely the grommet that should be mounted in your carpet. Listed HERE on eBay.
    kurtw[OP] likes this.
  7. May 14, 2020 at 6:38 PM
    4xdog
    Santa Fe, NM
  8. May 14, 2020 at 6:38 PM
    ABNFDC
    Granite State
    The carpeted floor mat may be throwing you off. The hook isn't upside down. The split post is simply broken. That is the style of clip that came with that year. The clips I linked earlier fit my 2008.
    4xdog[QUOTED] likes this.
  9. May 14, 2020 at 7:05 PM
    4xdog
    Santa Fe, NM
    Ahh -- I see that now. The tiny points would help it stay positioned on the carpet, so its orientation is indeed correct. My 2003 doesn't have those points on its clip.
    The mat retainer recall clips Toyota gives out (08210-00820) have a center pin to lock the split post in place. I've not used this kind.
