Floppy and loose shifter!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Apr 27, 2012.
  1. Apr 27, 2012 at 2:11 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    The shifter on my 96 auto 4x4 is really loose and does not lock in Place very well and I was wondering if I can pull that center console and replace a bushing or something to get it firm and to lock in place well. Just kind of wobbles around and it's starting to bug me. Any help would be great!
  2. Apr 27, 2012 at 2:19 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Can they be replaced easily?
  3. Apr 27, 2012 at 2:22 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Well I will tell you that it is moving more than normal
  4. Apr 27, 2012 at 2:24 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    floppy and loose? does it smell like badussy?
  5. Apr 27, 2012 at 2:31 PM
    jets
    jets Active Member
    805, CA
    2018 TRD OR DCSB
    I had the same problem on my taco what I did was grease the driveshaft and tightened all the bolts on the tranny underneath and as well as in the cab. I took out the center console and the cover from the automatic shifter and tightened all the bolts, made a huge difference in the sloppiness. :)
  6. Apr 27, 2012 at 2:34 PM
    Toyoda Tacoma
    Toyoda Tacoma Do or Do not there is no try.
    2019 TRD Double cab, Long box
    Roof Rack, Step Bars, 3” Rough Country lift 265/70/17 Goodyear DuraTracs
    Thats what she said. lol
  7. Apr 27, 2012 at 2:39 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Great love when someone's asking for help turns into a pool of everyones perverted comments. Let's keep it on topic
  8. Apr 27, 2012 at 4:42 PM
    Madjik_Man
    Colorado Front Range
  9. Apr 27, 2012 at 6:33 PM
    Robertgeejr1
    Robertgeejr1 Well-Known Member
    Robert
    Aorora, Ill, yeah!
    1996 Toyota Tacoma SR5 4x4
    I have done all the hi-pro mods for a life time, since I got this truck at a great price, I will be happy with showroom new.
  10. Apr 27, 2012 at 6:54 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Thanks for the help. Only one problem, I have a automatic trans and those are all for manuals
  11. Apr 27, 2012 at 7:01 PM
    Madjik_Man
    Sorry... overlooked that in your OP
    I'd just take the trim off and start diagnosing it yourself and see what you come up with.
    Good luck
  12. Apr 28, 2012 at 3:43 AM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    sorry, must be age that is getting me! I did not see that either....
    http://www.yotatech.com/f2/sloppy-automatic-shifter-161958/
    let me know is this is some help.
    let me tell you since up here we have had a "global warming spring" (and I love it) I have been under and in my truck scrubbing by hand and changing all the fluids, (the rear diff. looked like someone peed in a jar with a black crayon) the bolt looked ok, but shit, it is so easy to do this stuff on a 4x4 I just cannot believe people let stuff like this go. I have YET had to jack this truck up to do anything like this. I ran it up on a set of suv rhino ramps just to get all out of the diff. but it makes one hell of a difference.
    good luck, post if you need any help.
  13. Apr 28, 2012 at 1:26 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I'm pretty sure it's completely normal. There have been many threads regarding this issue. My auto shifter is the same way. It bounces around all over the place. One time it shifted into neutral :eek: But that was on terrible dirt road and I was going 50mph instead of 5...:eek:
  14. Apr 28, 2012 at 2:40 PM
    GuyHuey
    GuyHuey Up is difficult. Down is dangerous.
    Guy
    Holiday, Florida
    89 4Runner, 2020 MGM TRDOR 4X4
    Ball joint spacers and lift blocks, am I doing it right?
    If there's a lot of side to side movement it's most likely a bad bushing. There's two blue bushings that are used in Toyota automatic shifter's, they like to disintegrate over time. Most dealers stock them and if I remember right they were only a few bucks.
    You do have to remove the whole shifter to get to them, at least I did in my 4runner. I also had trouble disconnecting the wiring to the over-drive button. It was easier just to cut the wire's and solder them back together when I re-installed the shifter. The dealer even gave me a diagram, made the job easy, but a little time consuming.
    Guy,
  15. Apr 28, 2012 at 6:12 PM
    Robertgeejr1
    Robert
    Aorora, Ill, yeah!
    I don't want to drag is on, and waste your time, but since we both have 1996's I would check on the bushing. Now while I have never had a auto, I have driven plenty of them, and lots of miles, but it shouldn't be loose. before they passed away, my grandparents had a 96 camry, v6 and I remember the the shifter was very solid. And that car would fly.:D
  16. Apr 28, 2012 at 6:27 PM
    Bamahoyt
    Ted
    Knoxville, TN
    10-4 tomorrow is my truck work day
  17. Apr 30, 2012 at 11:25 AM
    Bamahoyt
    Ted
    Knoxville, TN
    Well I tore into my truck yesterday and all the play was I the linkages before anything got close to be transmission. I added a spacer for my side to side play and there is now no play side to side but looks like a bushing in another linkage needs replaced prety bad so it still goes front and back a good bit. It is much better now and I never had to take the shifter and boot off the trans. Just had the pull the cover and add some homemade bushings
  18. Aug 6, 2013 at 4:59 PM
    12Mk6gti
    12Mk6gti Well-Known Member
    Scott
    Sunshine state
    2019 Nautical Blue TRD OffRoad 4Runner
  19. Dec 13, 2017 at 4:44 PM
    vettehigh
    vettehigh Tacoma Tank
    Jon
    Upstate, NY
    I just received the 4 OEM blue bushings from Toyota for my 95 4x4 Auto V6. There are 4 total needed correct? Don't know if I have the know how to get it done. I removed the shifter console and I see the 2 bushings (they are totally broken) that are on both sides (left/right) of the T handle, but I do not see where the other 2 blue bushings go
  20. Dec 13, 2017 at 4:55 PM
    Mhelvic
    Mhelvic Active Member
    Crestview, Florida
    1999, PreRunner, XtraCab
    Don’t know if your having the same issue I had, mine is an automatic and I could shake my shifter side to side, and it could easily be pushed out of gear.
    See attached link.
    This was my issue. Bought new bushings off eBay for $14.00 and it took about 15 minutes to install. Did not have to completely remove shifter. Shifter now feels like new and is nice and tight and can’t be move out of gear unless the shifter button is pressed.
    I have a 99 and it only had two bushings. Don’t know if yours is different.
    https://youtu.be/lCY6XyxJjv4
    EMKFLYER likes this.
