Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Aug 20, 2013 at 6:25 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Okay this mechanical talk is above my knowledge level but can someone explain bearing preload?
  2. Aug 20, 2013 at 6:31 PM
    poundin tacos
    poundin tacos Well-Known Member
    Scot
    Dallas, TX/ SFL
    2021 TRD Off-Road, 2018 built Macan Turbo (daily), 2nd gen dodge, 89 944
    I have a brand new interstate mt-24 battery for sale. Bought it for my ex, never put it in. Still has the plastic around it. $50 if anyone wants it.
  3. Aug 20, 2013 at 6:31 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    in general terms, it's the amount of force on the bearings when a component is fully assembled and in a static state, with no outside forces on it.
    so in this case, picture the hub flange with the bearings pressed on, and the CV nut torqued to spec, but with no tire mounted, and the truck in the air. the bearings are under a load at that point, which is why they don't spin freely by hand.
    too much preload, and you can dent the bearing race, and prematurely wear the bearings/race. too little preload and you will either have, or quickly develop play in the hub. either scenario means broken or worn parts which create excessive heat and a bad hub.
  4. Aug 20, 2013 at 6:41 PM
    ckeene9
    Chesterfield, VA
    See Build Thread
    That makes sense, thanks!
  5. Aug 20, 2013 at 7:18 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    I'm lazy and the truck is dirty?
    I'll see what I can do photo wise.
    As I mentioned when I picked up the Avid bar, I have a bunch of parts awaiting install, just need time to accomplish it.
    Tranny cooler, convert oem cooler to PS cooler, Camburg upper arms, Magnaflow muffler, DTST headers and weld on cats, Torsen diff to build onto the third I picked up from TAC1 and install that, balance my newly mounted BFG Mud Terrains and install them. Need to pull my ICONs and send them back for new shafts, may just let it sit rather swap shocks on all four corners and then do it again a couple weeks later, plus I still need to finish the BAMF slider instll by drilling the rest of the frame bolts.
    I was able to find a set of tires a couple weeks ago. Mounted those the old fashioned way Sunday morning. Tire irons and a bucket. So I have my Mud Terrains mounted on the oem TRD sport 17" wheels, just need to balance them. I went by the tire shop suppliers outlet here in WPB to get the proper clip on balance weights. I figured they stocked the smaller all sizes weight kit, but unfortunately they don't. The guy was assuming I would buy boxes of 25 weights per box in all the sizes for the FN style weights. Wrong, it is nice to have a balancer at home, but spending a ton of money and having enough weights to balance 50 trucks seems wasteful.
    Between the day job teaching, fixing airplanes on the side, honey do stuff, maintaining the yard, helping the son in law sell his late fathers pro street 454 Chevy truck and motorcycle, spend time with grandkids and visit with my mom that's on chemo, seems the Tacoma always has little time to be or get finished. One day soon though.
    Holiday weekend coming though...
    PK
  6. Aug 20, 2013 at 7:25 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i just usually drive down the road to firestone and toss them a few dollars for some weights.
  7. Aug 20, 2013 at 7:29 PM
    PMK
    Florida
    10 DCLB TRD Sport
    It is true then that the inner bearing, next to the nut, is a press fit also? This just seems wrong for a double tapered bearing design component.
    I just can't recall this type of bearing installation on any other applications except front wheels.
    PK
  8. Aug 20, 2013 at 7:33 PM
    PMK
    Florida
    10 DCLB TRD Sport
    It may come to this, problem is though, I don't know if the local shops use the proper weights.
    My current selection has lead weights for steel rims on American cars. The Toyotas with alloys require a common but different wheel weight specific to the lip of the rim.
    PK
  9. Aug 20, 2013 at 7:37 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    what's the difference? lip contour?
    no idea what i have been using, but they always get torn off wheeling anyway :rolleyes:
  10. Aug 20, 2013 at 7:40 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Orange bada weights for Toyota
  11. Aug 20, 2013 at 7:54 PM
    PMK
    Florida
    10 DCLB TRD Sport
    The color code is orange, the lip profile is different shaped than other rim types. The proper weights fit pretty well onto the wheel.
    Have a look at your weights, look for the letters FN, that is the flange style or weight style that corresponds to orange.
    PK
  12. Aug 20, 2013 at 7:56 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i know for a fact then without even looking that about half of mine are american style. big ol' bulky deals compared to the ones that recess well.
  13. Aug 20, 2013 at 8:04 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I didn't mean only bada. Just the only ones I knew for a fact and they were orange. Should have clarified.
  14. Aug 20, 2013 at 8:38 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Jason, or anyone, my air/fuel ratio seems to be acting up. cruising and idle seems about right, fluctuating from 13-16, but even under WOT, it will not drop below 12.8. it also won't go above 18.12, but i just figured that was the normal upper limit. either way, is that screaming bad MAF sensor? i gave it a good clean, but it didn't really seem to change anything.
  15. Aug 21, 2013 at 3:33 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I will look up some info on it sometime today at work. Definitely seems something is weird with those numbers, just can't put my finger on it. I will get back to you.
  16. Aug 21, 2013 at 5:28 AM
    Toyota Tech31
    Debary, Florida
    Figured I would post a pic for those of you who know my son. Little man started kindergarten this morning. Had to brag a bit.
  17. Aug 21, 2013 at 5:29 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thank you :bowdown:
  18. Aug 21, 2013 at 5:33 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I miss kindergarten :(
    gone are the days where you do math with candy and then get to have a tasty treat when you're right or give the M&Ms to your neighbor when you're wrong.
    now i get fired when my math is wrong and no candy when it's right :eek::(
    hope he has a great day!
  19. Aug 21, 2013 at 5:34 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    Nothing better than a proud dad. Congratulations!
  20. Aug 21, 2013 at 5:49 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
