Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Aug 22, 2013 at 10:42 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Dumb question, but the paint for the lights, is it just flat black??? About to walk into lowes and pick some up.
  2. Aug 22, 2013 at 10:50 AM
    Manwithoutaplan
    ID
    that is a cool picture :thumbsup:
  3. Aug 22, 2013 at 10:55 AM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    http://www.roughcountry.com/toyota_4wd_tacoma_3.html
    thats the lift that I bought, it came with front spacers, the strut extenstions I believe they are called, and the rear 2" lift block blocks, U bolts and rear shock absorbers
  4. Aug 22, 2013 at 10:56 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    it's whatever you want it to be. i used flat
  5. Aug 22, 2013 at 11:01 AM
    Toyota Tech31
    Debary, Florida
    Thank you sir. I couldn't pass up that pic even if it did make people think I was casing the bank. ;(
    Thanks. David texted me the same about the flat black. Lowes didn't have what I wanted so I will stop by auto zone after I pick up Kyle and see if they have anything better.
  6. Aug 22, 2013 at 11:03 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    so with an extension like that, your shock isn't actually extended any further at ride height than in stock form. a preload spacer would extend the shock. in your case, you have increased the pressure on the spring.
    in stock form, the shock is what limits how far the suspension can drop. when you ad a spacer like that, you extend how far the suspension can drop, causing the shock to no longer be your limiting factor.
    lift your front end up off of the ground. if you still have the swaybar on, make sure to lift both front tires off of the ground. you'll have one of two things happening. 1) your upper controll arm will be hitting the coil spring. or 2) your upper control arm ball joint will be maxed out. either would make a clunking sound, but the arm hitting the spring would probably be louder.
    if the arm hits the spring, it's visually obvious that that's your issue. if it doesn't, the way to check if the upper ball joint is maxed out, is to unbolt the balljoint, separate it from the spindle, and see of the spring presses the spindle down further than the upper arm can reach.
    while possible, it's highly unlikely that it's a bad bushing (unless you have the old style SPC bushings in the aftermarket Light racing arms)
  7. Aug 22, 2013 at 11:14 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Great explanation, Colin. :thumbsup: Oh, and FWIW, I'd say go with an oil press gage. IMHO, it's probably the most important gage you can add if you don't have an OEM one.
  8. Aug 22, 2013 at 11:17 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thanks. that's what i was thinking with the oil pressure. current thought process is that it's more likely for my tranny temps to be too high evey now or then, but the concequinces are typically just a need for a premature fluid change. on the other hand, while it is far less likely to have an issue with oil pressure, if that goes bad, concequinces are catastrophic.
  9. Aug 22, 2013 at 11:18 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    hmmm, ya im not really too sure if i have the old style bushings or not, but if I can I can upload some pictures of everything behind the wheel and see if you can tell anything by looking, but im at work right now, so Im not able to do that, but I can once I get off at 4. But Ill have to see if I can check out what youre suggesting there once I get off, I really want to get rid of that sound, it sounds so bad, kinda wish at this point I wish I knew more about fixing vehicles lol
  10. Aug 22, 2013 at 11:20 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the more pictures the better. at the very least, we can hopefully rule out one or two of the suspects
  11. Aug 22, 2013 at 11:24 AM
    Alfuh
    2006 Prerunner
    I have a few mods
    awesome, Ill do that once I get off work, and thanks for all the help in advanced
  12. Aug 22, 2013 at 11:27 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    I feel a strong sense of attachment to those?????:alien:
  13. Aug 22, 2013 at 11:40 AM
    Toyota Tech31
    Debary, Florida
    Ha! You should! It took me forever to get all the glue off the lenses from the clear bra stuff you put on. But I got them looking like brand new when i was done with them.
  14. Aug 22, 2013 at 11:45 AM
    Taco No Baka
    Lee
    Tampa, FL
    Exactly. In fact, that's going to be my next project after I get the lift, wheels, and tires completed. I have an Autometer mechanical oil pressure gage I'm going to install. I just need to figure out what fittings I need so I can still use the OEM pressure sensor and don't end up with an idiot light on the dash glaring at me constantly.
  15. Aug 22, 2013 at 11:50 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i don't know abotu the first gens, but our seonds have a ton of open space in the gauges. why they couldn't just add one more small needle, i don't know........
  16. Aug 22, 2013 at 12:03 PM
    Taco No Baka
    Lee
    Tampa, FL
    My owner's manual shows a picture of a cluster with full instrumentation (speedo, tach, temp, oil press, volts, and fuel), so I'm guessing it was an option in '98s. Unfortunately, my truck is a few steps down from "barely adaquate" instrumentation. I don't even have a trip odo.
    When I do the oil press gage, I'm also going to install my way-over-kill Monster Tach (10,000 RPM) as well. It's going to be ridiculous for a stock engine, but since I've had it for years, might as well use it rather than letting it collect dust on a shelf.
  17. Aug 22, 2013 at 12:05 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I think you just set yourself a new goal...... :D
  18. Aug 22, 2013 at 12:14 PM
    Taco No Baka
    Lee
    Tampa, FL
    :eek:
    :burnrubber:
    :rofl:
    BTW, if you look closely at the pic of the '83 in my build thread, you can see said tach on the dash, so I guess the Taco is by no means the most ridiculous application this tach has seen.
  19. Aug 22, 2013 at 2:19 PM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    That was the most nerve wrecking interview ever
  20. Aug 22, 2013 at 2:50 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    So how did you do ??
