Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 1, 2013 at 8:19 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    Thanks for the info
  2. Dec 1, 2013 at 8:27 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Yeah, that Bed Coating is some really touchy stuff. It'll run instantly if you don't go on very light with the first couple of coats. Found that out the hard way on my sliders. However, I also found out that you can lightly brush the runs out with a paint brush while they are wet and they'll blend right in.
    And yeah, it's not like Bed Liner. It's just paint with a bit of texture (great for non-skid areas like sliders and such).
    Oh, and Home Depot has it for cheaper than Autozone. ;)
  3. Dec 1, 2013 at 8:36 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Nope, I'm pretty sure the LSD in the '07's were mechanical and not this auto BS.
  4. Dec 1, 2013 at 9:16 PM
    anders99
    Matthew
    Penscola, FL
    So i can't just put a switch?
  5. Dec 1, 2013 at 9:33 PM
    Taco No Baka
    Lee
    Tampa, FL
    No. The wiring is there, but none of the rest of the components are. For a diff lock, you'd have to have the E-locker rear end at least. Not sure what else would be required there. For ATRAC, I'm sure there's other stuff required for it to operate (sensors, computer, actuators to apply the brake on the wheel with no traction, etc...not too sure what all is involved with that).
  6. Dec 1, 2013 at 9:54 PM
    anders99
    Matthew
    Penscola, FL
    Well thats a bummer. Now I have this unused, unloved, and unwanted plug just dangling there behind my dash.
  7. Dec 2, 2013 at 12:05 AM
    Taco No Baka
    Lee
    Tampa, FL
    But...it would make your life infinitely simpler if you should ever decided to pony up the jack for an E-locker rear end. :cool:
    BTW, it's not just the one behind the dash. There's one back by the rear end too.
  8. Dec 2, 2013 at 4:41 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    No problem.
    Wasn't sure about the difference in years but all I have to work with is my 12.
  9. Dec 2, 2013 at 5:53 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    correct. works really well too with the right oil/s
    cheer up, the tradeoff is that you have a much stronger rear end ;)
  10. Dec 2, 2013 at 5:55 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Morning, all. :pccoffee:
    Fink
  11. Dec 2, 2013 at 5:59 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :wave:
    have a good thanksgiving?
    loved drooling over the photos of your old axial in the rc thread :drool:
  12. Dec 2, 2013 at 6:15 AM
    Fink
    Orlando, FL
    Great Thanksgiving! How was yours?
    Thanks man. I loved that thing. For me, though, it's almost more fun building and tinkering with them than running them. Depends on where you run them and what you're doing, of course.
    Fink
  13. Dec 2, 2013 at 6:40 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Yo dawg, I heard you like air fresheners. So I put an air freshener with an air freshener with an air freshener with an air freshener with ....... Aw fuck it, you get the point
  14. Dec 2, 2013 at 6:43 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    They should've saved the money they spent on the Auto LSD and applied it to something like better leaf springs. It doesn't work for crap!
  15. Dec 2, 2013 at 6:46 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    thats what is called a felony forrest. you just need some ddryer sheets hanging out of the air vents to try and throw the dog off!!
  16. Dec 2, 2013 at 7:14 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's a damn good thing they are fun to work on too, because i feel like i spend 2 minutes of wrench time on them for every 1 minute of run time lol. the quadcopters are the only exception, but that's because i run into a lot less with those lol.
    thanksgiving was fantastic. good to see the family after a 7 month gap.
    that's unfortunate. i've been so happy with the mechanical LSD (after i got away from the toyota recomemnded oil/mixture).
  17. Dec 2, 2013 at 7:26 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Its redline I know,,, what weight do you use:confused:
  18. Dec 2, 2013 at 7:27 AM
    anders99
    Matthew
    Penscola, FL
    Thats a thought but if when I put lockers in I am also going to be regearing and was thinking arb lockers.
  19. Dec 2, 2013 at 7:27 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    some red pepper:anonymous:
  20. Dec 2, 2013 at 7:50 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    well, at first, i used the mobil 1 full synthetic (75-90), but i left out the friction modifier LSD additive). that did wonders over dyno oil with the additive. now it's the redline heavy shock proof. redline makes a 75-90 (got that in my transfer case), but the heavy shock proff doesn't have a typical rating.
    quoted from their website:
    "Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90.
    Relatively low viscosity, yet cushions gear teeth under extreme pressure "
