Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jan 22, 2014 at 8:10 PM
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    Naw man ecpesially being that it is part of the system that
    Directs your vehicle away from walls and buildings i wouldnt
    Trust someone elses work
  2. Jan 22, 2014 at 8:13 PM
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
    Does anybody know how to bypass the clutch start switch
  3. Jan 22, 2014 at 8:14 PM
    Nicko
    Nicko beach bum
    Nicolas
    South Florida
    You should be able
    To just jump the wire or ground it and
    That should do it.
  4. Jan 22, 2014 at 8:16 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    i'm prob slow, but isn't the switch there to allow you to bypass the clutch, so if you don't want to, don't switch it on?
  5. Jan 22, 2014 at 8:20 PM
    michaelrussell
    Michael
    belleview,FL
    That's for 4x4 trucks only and a different switch I'm talking about the one under my dash that my clutch presses down on
  6. Jan 22, 2014 at 8:23 PM
    nammer
    Nam
    Bradenton, Florida
    so what's the purpose of your switch?
  7. Jan 22, 2014 at 8:25 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    im guessing your regretting having a manual with your injuries right now?
  8. Jan 22, 2014 at 8:40 PM
    michaelrussell
    Michael
    belleview,FL
    It won't let the truck start with out the clutch being pushed down
  9. Jan 22, 2014 at 8:44 PM
    michaelrussell
    Michael
    belleview,FL
    Yeah I tried driving it last week I got down to the end of my drive way and had turn around and park it because I was in to much pain so I'm stuck either having people drive me around or borrow my dads truck when he's not using it
  10. Jan 22, 2014 at 8:51 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Can you rpm match on those trannys? That way you only use the clutch to start and get out of 1st
  11. Jan 22, 2014 at 8:58 PM
    michaelrussell
    Michael
    belleview,FL
    Yeah I'm able to but I don't wanna risk messing up my synchro's
  12. Jan 22, 2014 at 9:05 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Some people ive talked to only rpm match. But I dont blame ya, mine doesnt always match up going into 3rd or 4th, and with all the shifting issues ive heard about with the 6spd I wouldnt do it either
  13. Jan 22, 2014 at 9:18 PM
    michaelrussell
    Michael
    belleview,FL
    I've got a 4 cylinder so it's only a 5 speed and I've done it before just to see if would work Allright also the way I do it is the same as if you were driving a semi
  14. Jan 22, 2014 at 9:18 PM
    anders99
    anders99 The Sailing Member
    Matthew
    Penscola, FL
    (07 Base 4cyl 4x4 - RIP) -> 2018 4Runner SR5 Premuim
    Taco SOS Offroad Concepts hybrid front bumper Iggy Corp. Switch panel Famous Fab ditch lights and cb antenna mount Pioneer Appradio 2 Halo Led Headlights Led Taillights 3'' toytech spacer lift on front end Toytec AAL on rear AFE cold air intake 4Runner Stock
    I am able to clutchless shift around 3100-3200 rpm no problems and no grinding sounds. I don't know about from a dead start though.
  15. Jan 23, 2014 at 4:31 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    Got my fl tacomas sticker, thanks tony 3e2u4yqy_8f5684bcd9e8d7b8ae2ae7c5fd51d74143ad3adb.jpg
  16. Jan 23, 2014 at 5:02 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Not sure about the Tacoma and my truck is auto so can't check. You might be able to either put a strong tywrap around it to hold it compressed or remove it from the mount and tywrap it. Or remove the switch and jumper the wires. (Maybe a paperclip and black tape until you heal up)
    My old 90 Nissan King Cab had the same feature. Not bad, but kind of a pain sometimes.
    PK
  17. Jan 23, 2014 at 5:23 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
  18. Jan 23, 2014 at 5:27 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
  19. Jan 23, 2014 at 6:58 AM
    TacoHell
    TacoHell Well-Known Member
    Colson
    Central FL (Orlando)
    98 Tacoma 2.7L
    Headers, K&N intake, Lifted, 4.56 gears via ECGS. Locked in front, LSD in the rear
    Great Food!! Been there several times and never been disappointed. Sounds like a good deal, would go if didn't have our own thing going on lol.
  20. Jan 23, 2014 at 7:52 AM
    4banger4x4
    Eric
    Whorelando, Fl
    Make sure kelsey is your server and tip her well, youll understand why
