Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jan 30, 2014 at 8:30 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    dont have time to watch it now but ill keep it on my tab.
  2. Jan 30, 2014 at 8:49 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
  3. Jan 30, 2014 at 8:59 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Rgr that. I do want to say, having rewatched some of it, I don't really approve of all the guy's practices--installing a bearing race with a steel chisel, for instance...he should have at least used a brass drift--but it does give you a pretty good picture of how the procedure goes. I also noticed that it's for an 8.9" axle from an FJ-40. Not sure if there's anything different from our axles other than size.
  4. Jan 30, 2014 at 9:48 PM
    nammer
    Nam
    Bradenton, Florida
  5. Jan 31, 2014 at 3:52 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
  6. Jan 31, 2014 at 4:35 AM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
  7. Jan 31, 2014 at 5:03 AM
    nammer
    Nam
    Bradenton, Florida
    Yea I did that it's showing me 495 shipped from headstrong ?
  8. Jan 31, 2014 at 11:21 AM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
  9. Jan 31, 2014 at 11:24 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Trail Graps
  10. Jan 31, 2014 at 11:35 AM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    X2
  11. Jan 31, 2014 at 11:43 AM
    Taco No Baka
    Lee
    Tampa, FL
    Lame...:p
    You should get a set of these...
    http://www.4wheelparts.com/Tires/35...aspx?t_c=13&t_s=158&t_pt=100821&t_pn=SSTB-118
    or these...
    http://www.4wheelparts.com/Tires/35...px?t_c=13&t_s=158&t_pt=100814&t_pn=SSTSSR-58R
    :D
    With that first set you'll go further in 2WD than folks could go in 4.
    (Edit: Sorry, had to live up to my title ;))
  12. Jan 31, 2014 at 12:08 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Buy mine.
  13. Jan 31, 2014 at 12:11 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    sweet, trail graps it is then...thanks!
    you tire snob :D Ill stick with my Nittos until I get my truck converted...then I may get Swampers....maybe, my current nittos are still fairly new, so after I get my parts and start getting my bumper built from Brute Force, Ill be getting the new tires...its gonna look so much better with the 35s than having my tiny 31.5s lol XD
  14. Jan 31, 2014 at 12:13 PM
    xweslingx
    Wes
    Durham, NC
  15. Jan 31, 2014 at 12:29 PM
    TacoHell
    TacoHell Well-Known Member
    Colson
    Central FL (Orlando)
    98 Tacoma 2.7L
    Headers, K&N intake, Lifted, 4.56 gears via ECGS. Locked in front, LSD in the rear
    ^^ that could be cool, probably something similar to hardrock.
  16. Jan 31, 2014 at 12:33 PM
    xweslingx
    Wes
    Durham, NC
    I'm going.
  17. Jan 31, 2014 at 12:40 PM
    TacoHell
    Colson
    98 Tacoma 2.7L
    I have to see what's up that next week in school, but id be down to go.
  18. Jan 31, 2014 at 12:42 PM
    xweslingx
    Wes
    Durham, NC
    I gotta do the same with school and work. Hopefully after taxes I'll have lockers to make this even more fun
  19. Jan 31, 2014 at 12:57 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Anyone here about the George Ximmerman celebrity boxing thing?
    The Game (a rapper) Apparently is interested.
  20. Jan 31, 2014 at 1:00 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Tiger says 3 day ban for anyone putting that name on TW.. Just a heads up..:)
