Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Feb 21, 2014 at 4:22 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    How old are the rear hubs. or it could be air in the lines.. but without being there its a stab in the dark..:(
  2. Feb 21, 2014 at 4:46 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    The hubs, I don't know. It looks like the brakes were done fairly recently. The paint on the springs is glossy and bright. All the hardware looks new. And the shoes and drums are still pretty flat, not nearly as grooved up as you would expect to see with more wear.
    The wheel seals aren't leaking, nor do the wheel cylinders appear to be leaking.
    I guess I could try bleeding the LSPV, but it's not really acting like people have described when the thing needed bleeding. When I installed the extended brake line, I bled the wheel cylinders pretty good, with a hose attached to the bleeder valve and the other end submerged in a clear glass bottle of brake fluid, bleeding them until no more bubbles came out. The pedal isn't spongy at all.
    Honestly, I'm starting to think I might need a longer extension bracket for the LSPV linkage. I might try taking it loose and wiring it up into a higher position to see if that improves things. Doesn't explain the E-brake junk though.
    Thanks for the ideas though. :)
  3. Feb 21, 2014 at 4:48 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    You are washing MUD off and re-adjusting everything????
    Even the little cams in the backing plates that HELP the e-brake function ???
    1st Gens like front brakes BUT LOVE to have no REAR brakes....
    I know it is a repetitive pain in the a$$ but CLEAN & ADJUST everything on that rear brake system....TIGHTLY....If bleeding the prop valve gives you piece of mind,include it...
    I just towed that trailer 1500 miles and looking at my front wheel brake dust you would think they did all the work BUT in driving I-95 traffic I NEVER would have stopped a loaded rig without the rears....ADJUSTMENT means everything..
    Just an "Old Man" opinion...;)
  4. Feb 21, 2014 at 4:52 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    Can you take a hub off and have it checked with a images_70b546235ad4e4da0622c861bccad1e7ff124d68.jpg:)
  5. Feb 21, 2014 at 5:01 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
  6. Feb 21, 2014 at 5:05 PM
    Taco No Baka
    Lee
    Tampa, FL
    I own one of those. And a set of Mitutoyo digital calipers. Although, I doubt my mic is big enough to measure the drum. You're talking about the drum, right? As opposed to the thing the bearing and wheel seal rides in?
  7. Feb 21, 2014 at 5:05 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    i have the 5" bracket from BAMF and its set all the way up. when your wheels are up in the air and you spin the wheels do you hear the shoe dragging on the drum?
  8. Feb 21, 2014 at 5:08 PM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    dayum dude..nice:eek:
  9. Feb 21, 2014 at 5:09 PM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, they had a nice coat of mud and junk on them. Not packed full or even all that thick, but definitely present. They are clean now though. And yeah, I'll be readjusting everything when I put it back together. I figure I'm going to entirely re-rig my E-brake mechanism from wheels to handle.
  10. Feb 21, 2014 at 5:14 PM
    Taco No Baka
    Lee
    Tampa, FL
    I only have Toytecs little 2.5 inch bracket. :p
    After I adjusted them this morning I did. Didn't seem to make much difference though.
    Okay, this is probably going to be a silly question, but what to shoes look like if they have been over-heated and crystallized? Never seen it before so I'm not sure what to look for.
  11. Feb 21, 2014 at 5:17 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    No more hood prop thanks to yotamikez giving me these redline tuning hood struts.
    Thanks again Mike & good to meet you.
  12. Feb 21, 2014 at 5:19 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I would have jumped on those if I wasn't sleeping when he posted it. That stinks.
  13. Feb 21, 2014 at 5:20 PM
    snoope
    EASY there, try that "cam-resurrection" 1st before throwing good $$$ away..
    I learned that le$$on quickly when the "Toyota Tech's" re-framed mine...I bought them lunch and they gave me great brakes....those "cams" are easily overlooked BUT well worth looking at....
    And cleaning/re-adjusting them is part of my "Spring PM" package after a NH winter.......Oh $hit, no more of those after this season...:D
  14. Feb 21, 2014 at 5:21 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Yeah but you got the shocks & that stinks on my end. Haha
  15. Feb 21, 2014 at 5:25 PM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    The drum,,, A auto parts store that turns them can check them for free ,, If they are to thin it can cuz problems images_b221ae16df7eedb3558a363e8d01af75f3c3f664.jpg
  16. Feb 21, 2014 at 5:29 PM
    4banger4x4
    Eric
    Whorelando, Fl
    No more good deals for you. Parts hog.
    Oh wait I dont have a 2nd gen :)
  17. Feb 21, 2014 at 5:30 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Lol I was just going to edit my post to say he can't hog all the deals.
  18. Feb 21, 2014 at 5:32 PM
    Toyota Tech31
    Debary, Florida
    I might have a hook up with some 10" fox remote resi's for the rear if you want me to look into it. Guy posted on my Instagram that he had them, near new and only wants $125 + shipping. I can see if they are still available if no one jumped on that killer deal already.
    :rolleyes::cool::D
  19. Feb 21, 2014 at 5:32 PM
    Toyota Tech31
    Debary, Florida
    Try to stop me!:p
  20. Feb 21, 2014 at 5:34 PM
    Taco No Baka
    Lee
    Tampa, FL
    Haha, when I said re-rig, I meant that from an aircraft tech's perspective: I'm just going to adjust the cable per manual spec from the wheels to the handle in the cab. Although I don't have a fish scale that reads ~40lbs, so I'll be guessing there. No $$$, just my time, which is free on my truck.
    I'll definitely look at them though. 'Preciate the advice. :D
