Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Mar 29, 2014 at 9:34 AM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Why's it gotta be a cheap shot? :confused: It's a perfect example. :D Nam wanted a TRD Sport hood scoop so he got a Sport hood and put it on. This guy wanted a Rustang front clip on his truck so he got one and put it on. Some folks think it's goofy, others think it's an improvement and a pretty cool mod. Wasn't characterizing Nam's mods one way or the other.
  2. Mar 29, 2014 at 9:47 AM
    Taco No Baka
    Lee
    Tampa, FL
    Agreed, but I don't know how bad I'd be rubbing on the floor pan/firewall. I do know right now with my sway bar unhooked, my LTBs are going to take a pretty hefty bite out of my fenders if I have the wheel turned at stuff. Also, I'm not sure how necessary tubbing would be if you SAS'd since you can set the axle fwd a bit to gain some clearance. In other words, I think the only way I'd go to 35s or larger is if I SAS'd. I just don't think the IFS CVs would handle it reliably...not in a locked front end anyway.
    You know, I just remembered you're running 35s and I haven't heard much about you breaking the front end...wheeling anyway. But then there's folks like Colson that run 35s and break the front end just about every time. Of course, Colson is also locked in front like me, so my experience would probably be closer to his, or worse, since I prefer extremely aggressive tires like Swampers and Boggers. Actually, I kind of expect that I'll pop a CV at Hardrock if I make it this coming trip.
  3. Mar 29, 2014 at 10:05 AM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    you'd take a hammer, grinder, welder and some sheet metal and fix the firewall issues. The cvs would handle 35s just fine as long as you know your limits and when to stop. I haven't really broken much since I started wheeling like calm human being. My only issues started when i was forcing my tires out of ruts and pissing off the steering rack as well as driving at 50+ down a trail. I still rub the firewall at full lock(hoping to fix that next week with some new UCAs. If i can't figure out how to weld soon, I might find a reputable 4x4 shop to tub my truck for me.
    As for SAS, yes I'd just move the axle forward and forget about it since id have full width axles but my only chance of an SAS at the moment are to find a buyer for my truck and get a 1st gen since theres more kits that include everything for first gens rather than 2nd gens..
  4. Mar 29, 2014 at 10:17 AM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Before I pull the trigger on tires. Lee how street friendly are swampers? Will they last longer than iroks?
  5. Mar 29, 2014 at 10:24 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Need bigger wheel wells :confused: [​IMG]:eek::D:cool:
  6. Mar 29, 2014 at 10:26 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    yea i'm pretty sure that's what the problem is, but still, at that height, i was surprised, cuse I used to only rub on passenger side, now I rub on both, just the tiny bit
  7. Mar 29, 2014 at 10:26 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    FIFY :)
  8. Mar 29, 2014 at 10:47 AM
    Taco No Baka
    Lee
    Tampa, FL
    I'd say they'd last about as long as IROKs. Basically the same compound with a slightly different tread patterns I'm guessing. No Interco off-road tire has a terribly impressive mileage expectancy because they are made with a relatively soft compound to increase off-road grip. However, if you don't put a lot of mileage on your truck, they will last a good long time. The Trxus radials I had on my F250 (a 7500 lb truck according to the scales at the dump) lasted 9 years, but only had about 10k on them before they finally gave up due to old age. They were nearly down to the wear bars when they started chipping and one separated (not catastrophically, but it developed the typical wear pattern).
    As far as street friendly, that's kind of a subjective question. it really depends on your expectations. If you expect them to handle like a good set of all-weather radials, you'll probably be disappointed. Mine don't ride bad after they warm up, but with bias ply tires like Swampers, Boggers, and IROKs, they'll be pretty rough after having been parked for a day or so. They get flat spots, but they get round again once they warm up. I pretty much drive like a grandpa :D, so I can't really speak about how they might handle during high speed maneuvering. In my experience though, I can't say they've done noticeably better or worse on the road (aside from wear) than any other mud terrain tire I've had, but they do develop a heck of a lot more traction off-road as a trade off for the poor wear.
    Hope that helps. :cool:
  9. Mar 29, 2014 at 10:47 AM
    xweslingx
    Wes
    Durham, NC
    More like I need a jeep and forget this tire fitting BS that comes with tacomas lol
  10. Mar 29, 2014 at 10:50 AM
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, I was gonna go with my die grinder and a ziz-wheel. There might be a BFH involved as well. :D
  11. Mar 29, 2014 at 11:02 AM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    I plan on getting 35s in the future, im not comfortable cutting my babies fenders all up. Id get the glass for the looks and not having to cut my fenders :D
  12. Mar 29, 2014 at 11:06 AM
    Taco No Baka
    Lee
    Tampa, FL
    Bite yer tongue. :eek: Sure, you don't have to deal with the tire fitting crap, but then you get to deal with the lack of reliability (coming from a former Jeep owner as well here--loved it, but I broke it every time I took it off road and sometimes without ever leaving the pavement--16x35 Boggers). :D
    Seriously though, IFS is a huge liability when it comes to building an off-road rig. It's a shame that Jeeps are the only thing you can get a straight axle in anymore...at least that isn't in the 1 ton truck or better range.
  13. Mar 29, 2014 at 11:38 AM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
  14. Mar 29, 2014 at 11:48 AM
    xweslingx
    Wes
    Durham, NC
    Dude, the easiest part of 35s is cutting the fenders. As said before, fiberglass is not a bolt on fit for 35s. You're gonna have to flatten the pinch weld then SEAL it well, beat the shit out your inner fender and cut away at the body mount. Im not seeing where everyone got the notion that bolting on fiberglass makes 35s fit lol:confused:
    you're right but you and I both know how cheap it was to replace the whole jeep over the weekend parts wise lol I just get jealous when my buddies just bolt on long arms and coil over conversion kits and BOOM tires below their sliders haha shoot even the guy in the land cruiser I wheeled with last weekend had some sick front end flex!
    hey now don't be posting porn on TW!:eek:
  15. Mar 29, 2014 at 11:53 AM
    nammer
    Nam
    Bradenton, Florida
    actually didn't know that at all! thanks :thumbsup:
  16. Mar 29, 2014 at 12:01 PM
    xweslingx
    Wes
    Durham, NC
    it might not have to be as extreme as what I did to mine with your maxtracs on but it'll still take some work
  17. Mar 29, 2014 at 12:03 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I haven't heard anyone say that's what they thought. I want them so i dont have to cut up my stock fenders and possibly make some money from them.
  18. Mar 29, 2014 at 12:04 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I think I'll just order the kevlars. The truck will not be driven often but the only decent priced swampers I can find are 16" wide for a 17" wheel.
  19. Mar 29, 2014 at 12:05 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I will be attempting to fit 40's on stock fenders. I'll keep y'all informed on how that works out.
  20. Mar 29, 2014 at 12:07 PM
    Toyota Tech31
    Debary, Florida
    I knew a guy running 40's on his taco. But he had like 12" total lift, including body.
