Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Mar 29, 2014 at 12:07 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Don't you know it.....:p...problem is just like "getting caught" looking :eek:
    I would "shut off" the boat fund ;)
  2. Mar 29, 2014 at 12:09 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Sounds promising lol.
    The truck will sit 5" taller over a stock truck on 16" coilovers at ride height.
  3. Mar 29, 2014 at 12:13 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    I didn't mean you of course. Was referring to Velcro's comment.
  4. Mar 29, 2014 at 12:17 PM
    xweslingx
    Wes
    Durham, NC
    with the full width axles you should be fine just make sure the links send ya forward a few inches and you'll be set
  5. Mar 29, 2014 at 12:18 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Plus I've already started the cutting and trimming process. Just need to do the BFH part when the time comes.
  6. Mar 29, 2014 at 12:18 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Actually, 35s may be that easy for the Prerunner crowd. They have those things like drop spindles and crap to get more than the 3 or so inches of lift us 4WD guys are limited to (without going long travel or DB).
    Far as the Jeep...I dunno. When I parted with it, I was on my ninth drive shaft, a dozen or so U-joints, third set of ring and pinions, 2nd T-case, 2nd ECU, and it had a shot clutch slave cylinder and a leaking rear axle seal...and I only had it a little more than a year. That's not counting all the stuff I repaired without buying new parts, like the cracked t-case tail housing (welded), tranny mount (fabbed one), and the rear axle tube that broke the rosette welds and spun in the diff housing (rewelded). :( 16x35 Boggers were brutal on the driveline.
  7. Mar 29, 2014 at 12:20 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Only going forward about an inch. I think I'll be alright.
  8. Mar 29, 2014 at 12:22 PM
    xweslingx
    Wes
    Durham, NC
    can I be there for that? should be fun and i'm running out of 4r excuses
  9. Mar 29, 2014 at 12:22 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Waiting on fuckin Fastenal for my new bumper and softopper.
  10. Mar 29, 2014 at 12:25 PM
    xweslingx
    Wes
    Durham, NC
    Im waiting on expo leafs and a custom shackle flip that probably will take a few more weeks...sucks
  11. Mar 29, 2014 at 12:29 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    At least you have you truck & not waiting on the truck & springs like I am.
  12. Mar 29, 2014 at 12:33 PM
    xweslingx
    Wes
    Durham, NC
    You have a good point sir. My springs won't be going on until I get the shackles anyway so you might just be up and running before me.
  13. Mar 29, 2014 at 12:37 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    If they really get them by the 1st like he said then I should have it back next week. Then I have to install my spindles.
  14. Mar 29, 2014 at 12:38 PM
    Toyota Tech31
    Debary, Florida
    "I need to stop by and say hi to Jason" sounds like a valid 4r excuse anytime.
  15. Mar 29, 2014 at 12:43 PM
    xweslingx
    Wes
    Durham, NC
    Right? I'll stick with that.
  16. Mar 29, 2014 at 1:11 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    ill be honest though Wes, I kinda just want the fenders for the looks lol, I honestly have only just been thinking of ideas and things I want to do next, havent looked fully into what I need to do especially with like what you were saying to fit the 35s, if I gotta cut...I gotta cut.
    next few things ill be workin on gettin' are Maxtrac spindles, sliders/hilift, and possibly a soft topper...still debating on this lol
    EDIT: I should prob throw getting a winch and hybrid bumper sometime in there too lol....
  17. Mar 29, 2014 at 1:15 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Why dont you buy all these beautiful 4wd components.
  18. Mar 29, 2014 at 1:17 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    my bank account is screaming at me to not spend money lol :eek: and plus, I have no time or anything to do the conversion
  19. Mar 29, 2014 at 1:19 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Buy the parts for later.
    If you're serious about the conversion I wouldn't waste money on spindles.
  20. Mar 29, 2014 at 1:37 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    scrap all that and get an ARB locker!
