Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 14, 2010 at 5:53 PM
    #5021
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    You're on the right track but a little off, there is no "boost" below 0 bar. Vacuum is read in the negative, because it is "sucking" once you get past 0 bar you are getting into "boost" and for a lack of a better term, you're "blowing".
    I beat you today.:D
  2. Dec 14, 2010 at 5:55 PM
    #5022
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Damnit, well I was more detailed and had two things to say so take that ha
    This is along the lines of the other link I posted except it's executed here
    http://www.pirate4x4.com/forum/showthread.php?t=725701
  3. Dec 14, 2010 at 5:55 PM
    #5023
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I would think that it would have to be a huge leaf blower, but still wouldn't be boost in any sense of the word.
  4. Dec 14, 2010 at 5:58 PM
    #5024
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    we may be misinterpreting each other, but i'm seeing it the other way around. if you have your intake drawing from static air, the higher rpm you're at, the more it has to suck in, and therfore, the higher the vaccume pressure will be. vacume pressure being the absolute value of boost, that would mean that it would go from 11 to say 15, or in terms of boost, -11 to -15. however, say you have a a "ram air" going faster, assuming the scoop works, will create a "boost" pressure. say it makes 2 lbs of boost at 50 mph, that means that your vaccume pressure is not 9, (boost = -9). whereas in a static system, you get no positive boost from flowing air, so it maintains the normal -11 boost.
    make any sense or am i jsut going crazy:eek:
    betcha you could if you're doing 250 mph :D
  5. Dec 14, 2010 at 5:58 PM
    #5025
    Jason'sLawnCare
    a mental boost :pout:
    Have you seen the video of the civic making 10 more hp with a hand held blower? I'm not sure if it's real but it's kind of funny.
  6. Dec 14, 2010 at 5:59 PM
    #5026
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i actually saw a youtube video of a car on a dyno a while back. they did a stock run, then pushed a leaf blower into the airbox, and actually got results. not great, but still results
    edit: jason beat me to it
  7. Dec 14, 2010 at 6:00 PM
    #5027
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Yeah that's the dude that did the cummins swap. he's in Milton Florida.
  8. Dec 14, 2010 at 6:01 PM
    #5028
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Today at school, since my Tacoma was covered in lime rock a few of my friends decided to draw big peckers on my doors and on the side of my bed along with a few words to go with.
  9. Dec 14, 2010 at 6:01 PM
    #5029
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    they had to build up the front and than test fit it and they are shipping everything in one big shipment. And the rears took alittle longer since there were so many orders.
    I cant wait for it to be done. I have no idea how to change all that stuff. I can do the dash and thats it. Sorry.
  10. Dec 14, 2010 at 6:01 PM
    #5030
    Jason'sLawnCare
    you crazy :crazy: The way I understand it the more the throttle is open the closer the vacuum is to zero that's why people use vacuum gauges to guide them to better mpg. The lower(higher number below zero to prevent confusion) the better they are controlling their lead foot.
  11. Dec 14, 2010 at 6:04 PM
    #5031
    Jason'sLawnCare
    I didn't even check out the location. May have to make a trip to pick his brain and check it out.
    That's right up your ally, represent!
    Gotcha
  12. Dec 14, 2010 at 6:06 PM
    #5032
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    but the more the throttle is open, the more air it has to suck. and to move more air, you need a higher pressure/force (to a point) no?
  13. Dec 14, 2010 at 6:06 PM
    #5033
    jjw1
    Jesse
    Jason, what do you mean thats right up my ally/represent?
  14. Dec 14, 2010 at 6:07 PM
    #5034
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Colin, I think I understand what you're saying if you mean absolute number for everthing you just stated, but you start losing me as the paragraph went on. I'm trying to understand, lol.
    Even if you're going 250mph, without forced induction the motor just can't suck that air in.
    Jason, the leaf blower idea on a dyno is actually not a real world number because it won't push near the amount of air as if the car was actually running down the street.
  15. Dec 14, 2010 at 6:08 PM
    #5035
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Did you take pictures?
  16. Dec 14, 2010 at 6:11 PM
    #5036
    jjw1
    Jesse
    No pics because I didnt have my camera on me at the time. I washed it off before I got home because I knew my parents would be pissed. The good side is I finally found my camera charger so when I go to Citrus i will definitely have pics up. The lil drawings and words are still ghosted on my truck so....
  17. Dec 14, 2010 at 6:14 PM
    #5037
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    sorry about that, it's hard to type this kind of stuff without confusing everyone (myself included)
    at super high speeds, it wouldn't technically suck the air in. the theorey is that while the intake valve to each piston is open, the pure speed of the vecile is so large, that it pushes more air into the chamber. so when the valve closes, you are left with a positive pressure. say 1, 2, or even 3 psi. of course you'll never get near the 8ish psi that a super charger puts out. this of course is all based on a scoop of sorts that actually works as a collector
  18. Dec 14, 2010 at 6:15 PM
    #5038
    Jason'sLawnCare
    I suck at explaining so check out the article and mostly the pic and you'll get an idea. The pinched part is the throttle position at idle and it opens up as you give it more gas.
    http://en.wikipedia.org/wiki/Venturi_effect
    I was accusing you of being a flamer. It was a joke though so keep your heart rate down.
    I'm sure it wouldn't work but it's fun to dream about. Plus I don't think I could fit my blower under my hood or run with my hood open
  19. Dec 14, 2010 at 6:18 PM
    #5039
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Boost isn't just air moving fast, it's pressurized.
  20. Dec 14, 2010 at 6:18 PM
    #5040
    Jason'sLawnCare
    :yay: I'm glad you found it. The "ghost" is probably super light scratches that will easily come out next wax.
    I don't think your hood scoop is capable of producing anything higher than atm because of it's shape, size, and location. I would think you would need a funnel.
