Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 14, 2010 at 6:19 PM
    #5041
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    So I'll have to hook up the air compressor and find a quick release valve, 120 pounds of boost here I come :eek: It'll be like nitrous.
    and if you put resistance on the blower tube you'll build up a tad bit of pressure.
  2. Dec 14, 2010 at 6:21 PM
    #5042
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    120 psi for .2 seconds, across 240 cubic iches....hmmm...it might clean the dirt of the top of your piston I suppose.
  3. Dec 14, 2010 at 6:23 PM
    #5043
    Jason'sLawnCare
    and it will make a chsshh sound so I'll be fast n furious dog
    The way my blower is designed it's basically a super unrefined turbo. It's not just a fan pushing air.
  4. Dec 14, 2010 at 6:24 PM
    #5044
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    You can't produce above atmospheric pressure period, no matter what your hood scoop looks like.
    Colin, by making your scoop functional the only thing it will do will provide the motor with cooler, denser air. Which will give you a minute gain in efficiency.
  5. Dec 14, 2010 at 6:25 PM
    #5045
    jjw1
    jjw1 Well-Known Member
    Jesse
    Citrus County Florida
    2011 Super White DCSB TRD OR PreRunner
    Weather Tech Floor Liners, Truxedo Bed Cover, OEM Silver Step Bars, Debadged, Colormatched Satoshi, Wet Okoles, OEM Roof Rack, Bed Mat, Locking Gas Cap, and removed Mud Flaps
    Me, a flamer, not hardly. I like (V) not 8==D
  6. Dec 14, 2010 at 6:26 PM
    #5046
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    You would have to connect it to your exhaust/backwards in order it for it to be a turbo.
  7. Dec 14, 2010 at 6:26 PM
    #5047
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    ok jason, now i see what you're talking about. i've taken more physics classes than i care to admit, so i know the venturi effect well. however, the pressure drop that is shown by the venturi effect is based on free flowing of the fluid on both ends. essentiall, that however much volume of a given fluid flows out of the tube, has infinate room to go. having a cylinder chamber on the end changes it though, since air that goes in cannot take up the space it needs to remain at the low pressure. now without forced induction, we aren't saying you build up a positive pressure in the chamber before cumbustion, it is just less of a negative pressure (closer to, but not equal to zero)
  8. Dec 14, 2010 at 6:26 PM
    #5048
    jjw1
    Jesse
    Yes, I am very excited that I found my camera charger. Stoked for the Citrus meet so I can load up the pics!!!
  9. Dec 14, 2010 at 6:26 PM
    #5049
    Jason'sLawnCare
  10. Dec 14, 2010 at 6:27 PM
    #5050
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the more i think about it, you're right, you will not overcome standard pressure. however, a scoop will be able to get closer to it.
  11. Dec 14, 2010 at 6:29 PM
    #5051
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    That's what I've been trying to say more or less the whole time, lol.
  12. Dec 14, 2010 at 6:32 PM
    #5052
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    You're engine just takes the denser air and creates a better mixture, returning a more efficient combustion without having to fuel anymore than normal. Better burn and better economy.
  13. Dec 14, 2010 at 6:32 PM
    #5053
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    the internet will do that to you :rolleyes:
  14. Dec 14, 2010 at 6:32 PM
    #5054
    Jason'sLawnCare
    yes, to be a true turbo.
    I figured it was something you could relate to. That's exactly what I'm talking about. So without forced induction in any way, shape, or form it is impossible to get to exactly 0 atm(but I guess thinking about it it's technically 1 atm and I've been using the term wrong, I just meant to shorten it) but it's close enough.
  15. Dec 14, 2010 at 6:35 PM
    #5055
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Kind of like that comment seems like you're calling me dumb I suppose?
    Out of context of course, right?:D
  16. Dec 14, 2010 at 6:36 PM
    #5056
    Jason'sLawnCare
    Phew, now that we got that out of the way.
    Tim, Do you think it's feasible to try to find the computer drawing of the needed toner ring and bring it to a machine shop or would they charge an arm and a leg? I've never dealt with a machine shop before.
  17. Dec 14, 2010 at 6:39 PM
    #5057
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Well, the guy I got the coilovers from is doing a 01-03 dana 60 with ford radius arms and he said you can just bore them out to accept nissans and account for tire size/tone ring teeth and the speedo should be good to go. brb, cig.
  18. Dec 14, 2010 at 6:40 PM
    #5058
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    correct, but denser air (assuming a standard temperature across the board) will be at a higher pressure.
    if you look at the ideal gass law: pv=rt
    p=pressure
    v=volume
    r=gas constant (ignore this)
    t=temperature
    take a given mas of air at one atmosphere and 70 degrees inside a bottle, if you open that bottle at sea level on a 70 degree day, air will neither enter or escape the bottle.
    however, if you take a larger mas of air (denser) in that same bottle, at sea level, on a 70 degree day, and open it, air will escape. it will do this to equalize the pressure with the outside air.
  19. Dec 14, 2010 at 6:41 PM
    #5059
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    no no no, i'm not calling you dumb by any means. just saying that this would probably be a 2 minute conversation in person because it's easier to understand each other
  20. Dec 14, 2010 at 6:43 PM
    #5060
    sneurath
    sneurath Well-Known Member
    shawn
    Hernando
    05 PreRunner SR5
    Whats up to my Fla Taco brothers? From Hernando County
