Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Dec 14, 2010 at 7:06 PM
    #5081
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i'm not a turbo guy, so i don't know what that means. are you talking about having two inline, instead of paralelle so to speak?
  2. Dec 14, 2010 at 7:08 PM
    #5082
    Jason'sLawnCare
    Jason'sLawnCare [OP] Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I don't think any of the regulars in here are but the two that I know of off the top of my head is Brunes(at least used to be, he hasn't had his location up for a while so I'm not sure if he moved or not.) and Jason but I can't think of his username, probably something to do with Gators.
    I think there is a thread for the panhandlers if you want to see who's in your neck of the woods.
    http://www.tacomaworld.com/forum/florida/85834-pensacola-area-tacos.html
  3. Dec 14, 2010 at 7:09 PM
    #5083
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    compound you have one turbo spooling the other its like twin turbo but not completely
  4. Dec 14, 2010 at 7:12 PM
    #5084
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i think you lost me. sounds like the point of it would be to have constant boost, with no lag ?
  5. Dec 14, 2010 at 7:15 PM
    #5085
    johnw
    john
    orlando florida
    damn i cant really type what i know like you were saying earlier its hard to say unless your in person
  6. Dec 14, 2010 at 7:17 PM
    #5086
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    A smaller turbo feeding a larger second turbo to spool it faster. Eliminating lag and being to build more powering with less psi. As psi is actually a measurment of restriction.
  7. Dec 14, 2010 at 7:20 PM
    #5087
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    no the way the air if filtered and put into the engine on our aircraft. no i dont wanna put a jet engine on my truck however that would be cool
  8. Dec 14, 2010 at 7:22 PM
    #5088
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    gotcha. so if you ran two of the same size it would put too much back pressure on the exhaust?
  9. Dec 14, 2010 at 7:24 PM
    #5089
    johnw
    john
    orlando florida
    it would be pointless because you wouldnt build boost fast thats why they do a smaller then larger turbo
  10. Dec 14, 2010 at 7:25 PM
    #5090
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    just ordered yellow lamin-x for my fogs :) the light output with the HIDs is great, but i'm trying to get the light to cut through bad weather a little better. it snowed last nihgt when i was driving home. the fogs did great, but they are just a bit too white, which washes things out a little in the snow. this should do the trick
  11. Dec 14, 2010 at 7:27 PM
    #5091
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ok, pretty sure i get it now.
  12. Dec 14, 2010 at 7:30 PM
    #5092
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    If you did two of the same size it would just be your traditional twin turbo set up. Which is like the middle....1 small/med, quick sppol, minimal lag, good power into the midrange, 1 large, slower spool in the lower rpms, lag, huge power at high rpm. 2 small/med quick spool, no lag, good power into the midrange and good power into higher rpm. Compound is no lag, power across the entire range.
  13. Dec 14, 2010 at 7:34 PM
    #5093
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ok, makes sense now. so if you had two big turbos, you'd have a shit ton of lag, but huge power at high rpm?
  14. Dec 14, 2010 at 7:36 PM
    #5094
    Jason'sLawnCare
    Ryan,
    Since you are in the mechanical circle, do you know of any welding courses around here? All I can find are places downtown and st. augustine. It seems that they also only offer full schedules to get the certifications/degrees. All I'm looking for is a basic class.
  15. Dec 14, 2010 at 7:37 PM
    #5095
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Exactly.
  16. Dec 14, 2010 at 7:38 PM
    #5096
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  17. Dec 14, 2010 at 7:39 PM
    #5097
    Jason'sLawnCare
  18. Dec 14, 2010 at 7:47 PM
    #5098
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, i remember your post a while ago about them raising their price.
    did you look at any other companies?
    I've been looking a the smittybuilt xrc8 comp http://www.quadratec.com/products/92122_1002_07.htm
    that guy i told you about who's our age up here with the lawn business is running one. he loves it. i didn't actually know about thw superwinch 9000 series until i saw it on your truck. the $200 difference really isn't that much in the grand scheme of things, i'm just curious what the extra money gets you. it's almost worth it for the plue line :D
    I was thinking about getting a steel cable winch and then buying a synthetic line for it, that way i will have a spare cable in case the line ever breaks on the trail. but....then i heard that the winches themselves are made differently. the synthitic line winches have the brake on th outside of the spool, because it gets so hot sometimes that it could melt the synthetic.
  19. Dec 14, 2010 at 7:53 PM
    #5099
    Jason'sLawnCare
    I did my research and found the general consensus to be that Warn and Superwinch were pretty much the top dogs. A few big things that attracted me to the superwinch are synthetic line, external brake(seems you are already familiar with the benefits), everything is sealed, and integrated solenoid that I knew would fit within my bumper and grill. I don't believe all winches that come with synthetic line have the brakes on the outside. With synthetic line if it breaks there is some sort of knot you can tie and continue to use it safely.
    With that said, I'm sure both will be more than enough for either of our applications.
  20. Dec 14, 2010 at 7:59 PM
    #5100
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yeah, the smittybuilt has the external brake as well on the comp (synthetic) version as well.
    is the superwinch a tight fit in your bumper? i think the all pro has slightly less room, so i'm wondering if it will actually fit. i need to go out and take measurements when it's not 16 degrees out.
    i've seen writeups on how to repair the synthetic rope. seen kets as well that come with the propper synthetic thread and needle.....i'm just not sure i trust myself enough to get it right.
