Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. May 19, 2014 at 12:16 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    Cause he's running 265's & your running a spacer which is pushing your coils down.
  2. May 19, 2014 at 12:23 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    tru, i never thought about the coil being pushed down
  3. May 19, 2014 at 12:28 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    Just trying to make you feel better.
    & damn 3 posts in one day.
    You had your chance.
  4. May 19, 2014 at 12:35 PM
    nammer
    Nam
    Bradenton, Florida
    don't worry be thought about you, there were numerous times, where someone said if rick were here, he'd be videotaping, and many of those times were in questionable positions
    haha, i'm typin up some long long paper for my wife, so i need TW to keep me distracted
    swapped rear blocks, and front top spacers
  5. May 19, 2014 at 12:42 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    my front end previously had 9" tread to fender, after the spindles, it's now 13" tread to fender, its about a 6"-7" of lift id say. Now im thinking about actually keeping the front as high as it is and seeing what my options are on raising the rear up....I really dont want to use blocks....but I dont think there is any other way of doing that. or I could just lower the front an inch or so
  6. May 19, 2014 at 12:48 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Yeah who needs down travel anyways.
  7. May 19, 2014 at 12:52 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    if I were to lower my COs to 0, my front would still be higher than it was before, and Id have all the down travel :p. ive only lost a small amount of down travel since i havent cranked the COs ALL the way up. I was glad I got rid of that crappy spacer lift, Nam...you need to get Coilovers and get rid of them spacers yo
  8. May 19, 2014 at 1:23 PM
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Blocks are fine if your just running around on the street. For off-road though, blocks - some soft of traction bar to prevent axle wrap = busted driveline parts and/or leaf springs. Blocks result in a lot more axle-wrap because they exert more leverage on the springs making the springs literally look like this ~. This leads to wheel hop when the tire finally breaks traction, which is when you start popping ujoints, tearing driveshafts in half, busting ring and pinions, and all sorts of other unpleasant stuff. Also, the spring repeatedly being forced into ~ this shape will cause it to fatigue prematurely and possibly fail (break in half).
    This is why people, who know, hate blocks.
  9. May 19, 2014 at 1:35 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    Well put bro. I've seen this happen too
  10. May 19, 2014 at 1:42 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    ^^^ this
    I dont want to use blocks to raise the rear, looking for other ways, I wish there were lift shackles for 2nd gens
  11. May 19, 2014 at 1:44 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    unless you have a TRD off road, the springs will be the weakest link when using blocks. if you have an off road, say bye bye to your R&P. driveshaft explosions/decintigration is more common with other makes/models. when properly maintained, i have yet to see a driveshaft go on a 2nd gen due to anything other than work out parts(no grease), or from and actual impact with an obstacle off road.
  12. May 19, 2014 at 1:44 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    If you get the a to shackle flip you can raise it.
  13. May 19, 2014 at 1:47 PM
    Taco No Baka
    Lee
    Tampa, FL
    You could get a shackle flip kit like Tim and Wes have. Also, you could hit up the local spring shop and see if they could re-arch your springs for you.
  14. May 19, 2014 at 1:57 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    ok, so this is what I've been a little confused about, I know with the front suspension add 1" spacer per say and you get 2" of lift. what about the rear? its just exactly whatever you put back there correct? my standards are giving me 3" of lift so if I wanted 6" of rear lift, a 6" leafpack would give me that correct? I never really thought about it until now
  15. May 19, 2014 at 1:58 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  16. May 19, 2014 at 2:00 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    Wes told me you can use Jeep XJ shackles with the kit and they are pretty cheap.
  17. May 19, 2014 at 2:04 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    are the XJ shackles longer or something to give more lift compared to the Tacos shackles?
  18. May 19, 2014 at 2:10 PM
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    They are longer, yes. You have to already have done the shackle flip though. It's a pretty straight forward install with no welding required. If you have the right tools and a friend, it shouldn't take more than a couple hours. Unless you run into problems like Wes did, lol.
  19. May 19, 2014 at 2:14 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I was about to say "with no welding" LOL not if you ask Wes.
  20. May 19, 2014 at 2:15 PM
    Alfuh
    2006 Prerunner
    I have a few mods
    hahaha lol, ya I know the rivets are the biggest pain to cut out, once they are out, the flip just bolts right in
