Florida B.S. Thread
Discussion in 'Florida' started by Jason'sLawnCare, Jun 19, 2010.
  1. Jun 28, 2014 at 7:43 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    damn, they are exactly the same, never would have thought. i call dibs on your 3rd
  2. Jun 28, 2014 at 9:37 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    exactly what my parents keep telling me....gonna look at some houses on Tuesday :rolleyes:
  3. Jun 28, 2014 at 9:43 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Fuck that, I dont wanna be managing properties when im old, maybe 1 or 2. But It would be shitty houses in a college town. Cost is low to buy and I could charge a shit ton
  4. Jun 28, 2014 at 9:47 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    two words Property Management
  5. Jun 28, 2014 at 9:49 PM
    xweslingx
    Wes
    Durham, NC
    that might be the ticket. I should probably go buy a house and stop dropping money into truck haha
  6. Jun 29, 2014 at 3:33 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    When I bought my TrueTrac, I was all over the internet researching. The internals are the same. The housing may be slightly different, honestly I forgot.
    This link was a big help
    http://home.4x4wire.com/erik/diffs/#rear
    FWIW, since I did not accomplish a gearing change, I bought the entire 50k mile third from TAC1 when he bought his clutch type locking Toyota diff assembly.
    I went with a TrueTrac. Picked up new ring gear bolts, and bought new oem carrier bearings from TAC1 also. I pressed the bearings onto the new diff. Then before disassembling the replacement third, I checked the gear clearance and noted it. Pulled the diff out of the third, and removed the bolts. These were Loctited and required some propane torch heat. Removed the ring gear, cleaned all threads and used a stone to ensure the bolt holes were flat. Installed the ring gear with new bolts and Loctite. Reassembled the diff and installed.
    What makes this model diff good is the girdle that prevents the carrier bearings from spreading and resulting in a broken ring gear or carrier.
    Also, this diff uses shims to set the side to side position of the carrier. The Danas and the elock Toyotas use a special threaded ring. This eliminates the need for shims, but it is a must do to reset the side clearance correctly.
    These diffs are easy to do yourself. The special tools are not really special. A quality dial indicator and magnetic or clamp on base to check the gear clearance before and after. A hydraulic press to install carrier bearings and clamp the diff to remove the ring gear bolts and reinstall them. Plus a good quality torque wrench. I did make one tool and if needed you can borrow it if you see the need. An aluminum spacer to press the bearings on.
    If you are changing gear ratios, then have ECGS or someone that does diffs do the work. The tools to remove the pinion bearings and time to set pinion depth makes those guys a bargain.
    FWIW, thirds are out there used or at the junkyards for short money.
    PK
  7. Jun 29, 2014 at 3:40 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Wes, what brand CV failed?
    Did it fail from a steering input or up and down wheel movement (too much droop)?
    Never followed the topics, but have seen mention of installing Tundra CV's into the Tacoma's. Might be an option or might not. Not something I follow closely since I have 2wd.
    PK
  8. Jun 29, 2014 at 5:07 AM
    xweslingx
    Wes
    Durham, NC
    It was a sur trac cv that failed at the outer. The aftermarket ones are known to fail easily though. My other side was toyota and it's still going strong. Not to mention I had the front end locked, drooped and turned when it failed. Took the truck to gattos and they gave me another sur trac cv for free as mine was under warranty.
    The tundra cvs are more for long travel 1st gens. All in all a cv is cake to replace and it was pretty fast this time around.
  9. Jun 29, 2014 at 6:15 AM
    4banger4x4
    Eric
    Whorelando, Fl
    Im all for DIY on my truck but I do draw a line when it comes to the diffs being that they cost so much just to buy the parts I might as wellspend the extra cash and have some one set it up properly and it comes with a 5 year warranty from ECGS.
    Also, my current diff is a junkyard find. Only cost me 400 shipped off ebay, but now that cheap find might be coming back to bite me. Ill find that out when I drain thediff today.
  10. Jun 29, 2014 at 8:57 AM
    4banger4x4
    Eric
    Whorelando, Fl
    This whole weord noise thing is getting old. Put my truck in the air again today and spun the tires and the clicking noise is coming fron the drivers side rear wheel this time. It almost sounds like tire rub, but its obviously not.
  11. Jun 29, 2014 at 10:20 AM
    PMK
    Florida
    10 DCLB TRD Sport
    Understand. ECGS does make it difficult to DIY. The prices are reasonable and the reputation seems good from what you read.
    PK
  12. Jun 29, 2014 at 12:32 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Yeah I already have a front ecgs, so why not make the set complete? I just oicked up some diff fluid so im gonna drain it and see what I find and if I dont find anything im gonna pull the axles and see if there is any abnormal wear on the axles or new bearings that would be causing the noise.
  13. Jun 29, 2014 at 1:24 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Got a visit from Fink today. Installed his new wheels/tires, programmed his tire sensors, and aligned it for him. I like the wheels and tires. They are so cute next to mine.
  14. Jun 29, 2014 at 5:02 PM
    4banger4x4
    Eric
    Whorelando, Fl
  15. Jun 29, 2014 at 6:04 PM
    xweslingx
    Wes
    Durham, NC
  16. Jun 29, 2014 at 7:55 PM
    PMK
    Florida
    10 DCLB TRD Sport
    Again this is a pretty easy install for the diff. But, with his third, and a diff, you are getting up there in price.
    What diff did you want to install?
    Jupiter, is not far for me (25 minutes), so it could be swapped over pretty easy if you brought the parts or sent them ahead of time. We are supposed to be going to Lake Wales for a bicycle event in early August...
    PK
  17. Jun 29, 2014 at 8:10 PM
    4banger4x4
    Eric
    Whorelando, Fl
    ive got the swap covered. i just pulled the diff 2 weeks ago so i could do the wheel bearings axle seals and reseal the diff. and ive also regeared once already by myself front and rear.
    thanks for the offer though. plus between me thinking and wes talking, i dont want another open diff
  18. Jun 29, 2014 at 10:40 PM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    hey for the Konig Six shooter wheels do they only come in a 17" wheel? thats what ive seen so far. I was helping a friend out install his lift on his Taco today and he had a set of Konig six shooters to replace his stock sports and without the center caps I really did love the way they looked on his truck and is really tempting to get a set but I was hoping they had a set of 16s instead of 17s
  19. Jun 30, 2014 at 12:58 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
  20. Jun 30, 2014 at 3:30 AM
    4banger4x4
    Eric
    Whorelando, Fl
    But you have wheels, time to get lockers
